50 not running right
Old Oct 2, 2004 | 07:02 PM
cbxr50's Avatar
I pulled my motor to paint the frame and when i put it back in it will not run for crap. It is cutting out and backfiring. I pulled the carb and cleaned it out, adjested the needle all the way down(trying to limit the amount of fuel dropping in the carb) and also checked the plug. I didnt do anything to it besides unbolt the motor and it was running fine. I dont know. Any suggestions would be appreciated. I also am running a uni air filter with a stock pipe with the baffles removed. thanks
Old Oct 2, 2004 | 08:06 PM
rdccarpet's Avatar
rdccarpet is an unknown quantity at this point
Re: 50 not running right
check your ground clean any paint off of where u bolt your ground to
Old Oct 3, 2004 | 01:08 AM
cbxr50's Avatar
your a lifesaver!! ground bolt was loose.
Like joe dirt says "life's a garden, dig it"!
Old Oct 3, 2004 | 12:16 PM
Kev900RR's Avatar
Thats what I would've said, sounded like a spark problem
Old Oct 4, 2004 | 12:23 PM
MITTER's Avatar
MITTER is an unknown quantity at this point
This fix needs to be a sticky. just seems that there is about one of these a month, always the same problem after a frame gets painted
1wr4life
Jan 31, 2014 03:13 PM
steelcityrider
Jun 18, 2013 01:04 AM
zx6rlover
Apr 17, 2013 05:26 PM
zeus_r6
Apr 2, 2013 04:26 PM
gotafurrybike
Feb 11, 2013 03:43 PM
