Kitaco 88cc Bore kit popping noise like timming is off?
I have installed 1-2 bore kits before. For some reason i can not get this Kitaco 88 cc with stock head and intake. My takegawa ran great untill someone stole my FIDDY !! It was pimped out!!
But i can get this running and idleing but any high revs the intake sounds like its popping and snapping!! I have the timming on point! What the hell is going on
Please help me out !!!!!!!!!!!!!!!!!!!!
Re: Kitaco 88cc Bore kit popping noise like timming is off?
Oh yea i have cam too and valve lash seems to be adjusted just fine. I have no idea whats going on. I also think when it pops and snaps the intake shoots out oil I think??
i Have the needle 2nd from the bottom and 1 1/2 turns out ? Perfect setup? I dont se whats going on. I I juat installed the kit again and same ****. This time wiht the valves a little loose.
i dont see whats going on. It feels like its hitting the rev limiter but no way this early. NO way my stock fiddy would blow this thing away!!
Would gaskets or anything create this problem?
That same thing happened to my buddy's fiddy. When I took it apart, the guy who installed the big bore forgot to put a couple of the locator dowels back in the head and cyl. It ended up shifting the head and blowing the head gasket. Even if the pins are right, I have seen the head gasket blow with the same kind of noise. Check that maybe
OK I found the Problem!!
The small dowel washer like between the cam and the cam sprocket i had missing !! I am such a idiot!! Well I got my fiddy up and running !! Time to start killing it!!
Thanks for the help!!!
Originally Posted by Jimbo7
Mine did the same thing till I jetted it down (leaner). It could also be valve float if its revving high.
phee0220
For Sale & Wanted
03-13-2014 12:04 PM
phee0220
01-12-2014 10:00 PM
phee0220
12-23-2013 01:44 PM
shugga
11-13-2002 02:43 PM
