Honda Trailbikes Manual Clutch question
Old May 25, 2004 | 10:51 AM
jquest1234's Avatar
jquest1234 is an unknown quantity at this point
If someone can help me with the order I will write up a HOW TO DOCUMENT with pictures so it will make it easier on the next person
Here is what I did
1st = I removed all the stock clutch parts and gears
2nd = I installed the large gear next to #11
3rd = I installed the #11 on the back of #12
Question?
Under #13 I installed #10 first, #9, then the lock nut
Then I bent the tab onto the lock nut
On top of #13 I installed #7, put #6 inside #7, and then #5(spring)
If I have installed all of the correctly, where does #9 GO????????
Thanks
Old May 25, 2004 | 11:22 AM
bigwhiteboy's Avatar
CEO of o2w
bigwhiteboy is an unknown quantity at this point
Re: Honda Trailbikes Manual Clutch question
Question?
Thanks
you said you put 9 in already?????
anyway for now take a look at these pics, and make sure you have everything as it is suposed to be..if you need bigger ones let me know...
ID:	80803   Click image for larger version
Old May 25, 2004 | 11:29 AM
CEO of o2w
here are the larger ones....
http://store6.yimg.com/I/dratv_1795_25427000
http://store6.yimg.com/I/dratv_1795_25771033
Old May 25, 2004 | 12:31 PM
jquest1234's Avatar
[QUOTE=bigwhiteboy]here are the larger ones....
It looks like #13 in your picture is what I was referring to in mine as #9.
Thanks,
Jon
Old May 25, 2004 | 04:16 PM
it goes under yer #11 gear. u most likely left the old one which is fine since its the same part.
Old May 25, 2004 | 04:22 PM
jquest1234's Avatar
Yep, that's what I did. Left the stock one on. I am debating on tearing it apart and switching them. I am not 100% sure it's there.. Better safe than broken.
Tomorrows the day I am going to crank the engine for the first time.... Fingers are crossed that everthing is setup correctly. I installed the 88cc kit and clutch... :YEAH
Old May 25, 2004 | 05:09 PM
put a 15t front on that bitch and u will love it
Old May 25, 2004 | 05:30 PM
jquest1234's Avatar
I've got a 15 tooth installed already. I have a 33 tooth and 35 tooth rear. Going to play with a few different gearing ideas to find a happy place
Thanks
Old May 26, 2004 | 05:52 AM
keep in mind that the tranny drive gears are a higher ratio that the automatic ones u swapped out.
stuntin'_cbr
Nov 20, 2024 11:08 PM
oscar600
Apr 25, 2015 08:44 AM
zeus_r6
Aug 23, 2014 04:11 PM
JerZey
Nov 12, 2012 12:06 PM
eamonhoffman
Oct 14, 2012 07:51 PM
