rear brake light w/ microswitch on lever?
Old Mar 15, 2004 | 12:48 PM
potential's Avatar
potential is a decent person
i'm gonna rewind my stator w/in a few weeks time and i figured i might as well try to hook up a microswitch on the lever and get a brake light. it shouldn't be too hard but i don't know about all those older monkey and gorilla parts, i thought maybe one of those levers/switches should work but i don't know. has anyone done this? would it drain too much juice from the headlight? if it's gonna be too much of a pain i'll just forget it but i though it'd be cool to have one on the streets. and has anyone found a good waterproof switch to use for the headlight? i wanna have be able to turn it off.
B
Old Mar 15, 2004 | 01:02 PM
Z50NATIONALS's Avatar
Re: rear brake light w/ microswitch on lever?
use a old stlye 50 cable from honda has the brake light switch built into the cable you just plug it in
thought it was for a front brake
if not my bad
Old Mar 15, 2004 | 01:26 PM
potential's Avatar
no that's cool thanks for the lead. anyone else know where that part came from?
B
Old Mar 15, 2004 | 01:28 PM
i got this one at the honda dealer
Old Mar 15, 2004 | 02:26 PM
potential's Avatar
cool so have you rigged it up and gotten it to work? does it just wire in-line to the brake light? (like a circuit i guess). and... is that a coloring book??
B
Old Mar 15, 2004 | 03:06 PM
yes it just wires it into the circuit,you pull the cable closes the ground you have brake light,the older z 50's had these on the front and rear brakes
and no its not a coloring book
it is a design im putting on a guitar
Old Mar 15, 2004 | 03:09 PM
potential's Avatar
haha sorry bout that, but thanks for the info i'll check that out, is the brake cable plenty long? i have a bar kit w/ +1"s...
B
Old Mar 15, 2004 | 03:21 PM
Yes , it will
the older bars were real tall
im gonna use it on my set up when i do lights
i got bars and 70 forks
plenty long enough for it
Old Mar 15, 2004 | 03:27 PM
potential's Avatar
thanks a lot man. should i run a separate circuit for the headlight and brakelight?? i guess i'll have to since i wanted to hook up an on/off switch for the headlight.
B
Old Mar 15, 2004 | 04:18 PM
ZYIFIDDY's Avatar
ZYIFIDDY is an unknown quantity at this point
headlight and tail light should be one circuit
and the brakelight will be another
stuntin'_cbr
Nov 20, 2024 11:08 PM
nsschwenk
Oct 16, 2012 06:31 PM
nsschwenk
Oct 16, 2012 02:10 PM
Jay Carnes
Oct 17, 2002 03:25 PM
