Stock Exhaust/Carb Mod???
Old Feb 18, 2004 | 02:18 PM
Dano's Avatar
It Ain't Easy Bein Cheesy
what's the dilly with the stock carb and exhaust mod's? i've heard they exist but no nothing about them. do they make a noticable difference? i'd imagine the carb has a restrictor plate in it that could be removed, but i have no idea what the exhaust mod could be. someone please enlighten me....
btw i have an 04crf
Old Feb 18, 2004 | 02:49 PM
potential's Avatar
potential is a decent person
Re: Stock Exhaust/Carb Mod???
no carb mods out there that are worthwile... jokermachine.com sells a silly plug to get rid of the choke feature (they claim it adds more power), anything other than that is jetting and tuning, it's just a small carb that's all, lots of kids get filters and rejet but i don't like the idea of an open filter/no box (just sucks in dirt and sounds like 'bOOOOp'). for exhaust lots of kids are removing the stock spark arrestor by cutting it off of the endcap and putting the cap back on, but i don't think it's even worth you're time b/c i have never noticed any difference when putting a friends endcaps on my bike - feels the same to me, plus it makes a horrid tinny sound (sounds like ****). as far as i'm concerned there aren't any cheap, worthwhile mods to make more of power outta a fiddy, gotta pay to play...
B
Old Feb 18, 2004 | 02:54 PM
J.L.'s Avatar
J.L. is an unknown quantity at this point
I put a 60 main jet and unifilter on mine and picked up a little. Not much but worth the twenty bucks a jet and filter are gonna cost.
Old Feb 18, 2004 | 08:41 PM
sandmrider's Avatar
Alright....I just did a bunch of free mods to my fiddy and you CAN feel the difference. I can beat my friends w/ stockers with ease. All of these mods cost nothing...
-Take off airbox. Take it apart and rip out the screen thing in it. Drill holes in the metal thing after the opening for the air (you will know what im talkin about when u see it) Drill holes in the plastic piece by the opening. Cut off the opening.
-Take the choke off the carb. You never use it anyways. Use a bolt a little bigger than the opening of the hole the choke came out of to seal it shut. You should probably lock-tite it in, but mine's stayin so far.
-Take off the intake manifold thing. The end going to the head has a smaller opening than the opening in the head. Take a dremel and grind the hole bigger.
-Take off the exhaust and look at the header end. If you feel in there you can tell that there is a weld that can be grinded down to be the same size as the rest of the pipe.
-Take off the end cap. Drill some holes in the cap thing on the end by the screen thing. When i did this mod i also shoved some fiberglass insulation inside the first "section" of the pipe where it wont effect the air flow. You have to put it in there with an opening to fit the end cap in. I did it to see if it would make it quieter and i dont know if it did but o well.
-Now you will be flowing more air so you will need to rejet the carb. I raised the needle by puttin it on the slot second from the bottom. I probably also need a bigger main jet, but it runs ok now. Ill try it later.
Have fun
Old Feb 19, 2004 | 05:40 PM
Have fun
I did all of the above last week and it made a huge difference. Although I have a K&N filter and I cut off the spark arrestor altogether
Old Feb 19, 2004 | 07:29 PM
sandmrider's Avatar
how much louder is it with the spark arrestor cut off?
Old Feb 19, 2004 | 07:34 PM
I was very worried about noise, but it really isn't bad at all... I cut it about 1" past the arrestor and into the silencer
Old Feb 20, 2004 | 04:36 PM
MITTER's Avatar
MITTER is an unknown quantity at this point
When you remove the choke do you just thread a bigger bolt in or do you tap it for the bigger bolt?
Old Feb 20, 2004 | 04:38 PM
Whats the advantage to removing the choke?
Old Feb 20, 2004 | 04:46 PM
vegas's Avatar
vegas is an unknown quantity at this point
it lets just a lil more air in, bit its a bitch to start in the winter
Old Feb 20, 2004 | 04:51 PM
we have no winter....
I wonder if that'd be worth it to do
Old Feb 20, 2004 | 05:13 PM
Silver Surfer's Avatar
Bastards...........
I'm going back to Tampa.
Old Feb 20, 2004 | 07:39 PM
Mr Weber's Avatar
Mr Weber is an unknown quantity at this point
:YEAH I cut off my spark arrestor, raised my needle 2 notches, and turned my mixture screw out 1/4 of a turn!!I have a new crf 50, and it is alot more responsive, and seems to have a little more power!!!
Old Feb 21, 2004 | 11:48 AM
sandmrider's Avatar
I just screwed in a bolt layin around and it seems to be stayin. With the choke off it should be flowin more air. It still starts easy.
Old Feb 21, 2004 | 02:11 PM
When you say you turned it out 1/4 turn.. is that from the stock position or is that from all the way in?
Old Feb 22, 2004 | 03:58 AM
Mr Weber's Avatar
That is from the stock setting!!
Old Feb 22, 2004 | 04:47 AM
vegas's Avatar
alright i just did all of the mods listed above. took bout two hours... and man was it worth it...i got a pod filter at the local shop but i have on question for those with one... what did you do with the crankcase vent that was hooked up to the air box post filter? i just left mine for now but i think that im gonna try and rig it so that it is sucking in filtered air as opposed to unfiltered. what are you guys doing with it?
Old Feb 22, 2004 | 04:50 AM
vegas's Avatar
oh yeah i found one more thing that you can do
-take off the baffle and shine a flash light in the exhaust, there is a screen in there. i bashed mine with a long pry bar and hammer until it was gone. i dont know if it made a difference but its peace of mind to know that the exhaust is completely clear meow.
good luck guys
Old Feb 22, 2004 | 01:32 PM
Just tuck that tube up under the frame or something..
as for the spark arrestor.. I cut it off bout 2 inches past the mesh thing.. made a nice diff
Old Feb 23, 2004 | 01:06 AM
vegas's Avatar
no further in the exhaust is another screen
