air filter--
Old Nov 11, 2003 | 09:01 PM
boardin4life's Avatar
boardin4life is an unknown quantity at this point
air filter--
How much does a K&N air filter do for you?? Do you even notice the difference and haul oats or is it nothin at all?
Old Nov 11, 2003 | 09:48 PM
monkey-nuts is an unknown quantity at this point
K&N
When I slapped on the K&N filter on my fiddy it made slight difference.Made it sound meaner,because of all the air. but you have to re route the crank case breather tube.But you should jet it after you buy it soo it evens things out. Playing with the stock carb's not that hard!!! just Lower the clip of the jet-needle. try second from bottom groove, and turn the air-screw out 1 3/4...
Old Nov 12, 2003 | 02:40 AM
Silver Surfer's Avatar
Buy a UNI foam filter. Use a #60 jet when jetting the carb. That should get you a little more performance.
Old Dec 4, 2003 | 08:59 PM
sledneck's Avatar
sledneck is an unknown quantity at this point
my k&n filter on my scrammy helped alot......I noticed a big difference in low end, and a little on top
Bryan
Old Dec 7, 2003 | 12:09 AM
redrider954's Avatar
redrider954 is an unknown quantity at this point
get a uni pod filter and a 62 jet or a 60 and it will screw.
Squidlife92
Stunting Help and Advice
Apr 20, 2014 09:02 PM
DJPlayer
Sep 26, 2013 08:54 AM
Clutch n' Chris
May 23, 2013 05:06 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
the fast one
37
Feb 1, 2003 10:38 PM
