FUEL for the FIDDY ???????
I have been wondering for a long time if higher octain fuel in the fiddy would be any better. bc in stuntlife someone said that 4-strokes need fast burning fuel (87) octain. THAT'S A LIE. Well last weekend i filled up with cam2 (112) octain. I have been checking the carb and sparkplug to make sure everything in good. it liiks good to me so far so i'm going to keep running it in the fiddy. with the upgrades that i have done it has shown me some performance that i have really been looking for. Does anyone know anything that it can do to my fiddy in the long run. or have any input????????? THANKS
Here is what I know....
Back in my drag racing days it was always said that a vehicle will not need a high octane fuel unless cylinder pressure and or heat are above the levels that a low octane gas can handle. If the cylinder pressure/heat levels are too high for a low octane fuel it will cause preignition also known as detonation. Detonation occurs when the air/fuel mixture temp is high enough to ignite without a sourse of ignition (spark). Detonation usually occurs in an application where a high horespower vehicle with a high compression ratio or forced induction is not running a high enough octane fuel.
So.... I don't think a basically stock xr50 motor with 2.5 hp needs a high octane fuel. xr50's are not are not finicky high compression motors or force inducted the last time I checked. Actually low octane fuel should give you MORE horsepower because the air/fuel mixture will....
a)be easier to ignite with the given ignition spark
b)cause a more efficient/rapid explosion in the combustion chamber.
My friends and I got ahold of some methanol alcohol. All we did was mix the ratio 4/1 and it ran a whole lot better. Even feels like I gained more horsepower. We got arenacross on the 20th I will let you guys know how it runs.
it won't help running higher octane. you won't find a gain unless you alter something like running higher compression or advanced timing.
you'll probably run better on 87 because that's what the engine is made for, or at least until you mod it out pretty good. to get the best performence run the lowest octane you can without causing detonation.
Originally posted by MXgraham044
i wonder what would happen if you put some nitro methane in a fiddy.
fab5fiddy
--*CBR*KING*--
Apr 5, 2022 11:42 AM
(Brandon)
May 3, 2014 07:30 PM
