K&N air filter install
Old Jun 1, 2007 | 10:39 PM
Joeyblitz's Avatar
Magnificent Ruffian
Joeyblitz is an unknown quantity at this point
Just got the K&N for my 01' XR50 and I noticed a breather line out of the crankcase to the stock airbox. Is it safe to plug this up or do I have to let it hang ,or re-route it .Also what to do with the ground wire on the front of stock airbox?
Old Jun 1, 2007 | 10:46 PM
Re: K&N air filter install
the tube is a vent for the crank case don't block it off maybe get a little K&N automotive valve cover breather for it ,that would be pimp
and if the wire is just a ground then just ground it some where else
Old Jun 11, 2007 | 03:16 PM
Joeyblitz's Avatar
Magnificent Ruffian
thanx again roger!! as usual,you are the ******' sensi of all things stunt related.
alicia417
Jul 20, 2013 07:45 PM
Clutch n' Chris
May 23, 2013 05:06 PM
Brian94tt
Apr 12, 2013 07:40 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
NYkid891
Nov 28, 2012 10:06 PM
