Air Filter install Help?
I have a Twin air bolt on filter for my xr50, will i have to adjust anything if i put it in, and where does the hose go that connects to the old air filter assembly? Thanks
Re: Air Filter install Help?
Run the hose out the back of teh bike ( mines between the frame and motor facing the ground)
you'll probably need to adjust the idle mixture screw and raise teh needle up a bit to compensate for the extra incoming air....easy stuff
Was wondering the same thing. I got rid of the spark arrester and got an air filter. I also live in Hawaii. Should I change my main jet to 60 and leave the clip pos. in the middle.
you dont really need to change your jetting unless you get a new exhuast...and for the clip position i suggest just playing around with it and see what works best for the conditions down there. carbs are always a touchy and differ from bike to bike
Right on. Maybe I should just leave it alone. I checked the plug and it's burning good. Had to play with the air screw a little.
