Stripped Nut On Sprocket!!!!
Old Sep 16, 2006 | 09:42 PM
yungstunna17's Avatar
yungstunna17 is an unknown quantity at this point
Angry Stripped Nut On Sprocket!!!!
I Stripped The Nut Trying To Take Off The Sprocket. The Nut Is Starting To Round Off A Little Bit. Before I Do Any More Damage How Do You Think I'll Be Able To Get It Loose With Out Rounding It Off More.....vise Grips Maybe????
Old Sep 16, 2006 | 09:45 PM
motopsyko32's Avatar
motopsyko32 will become famous soon enough
Re: Stripped Nut On Sprocket!!!!
20 bucks at Sears... best investment ever
http://www.sears.com/sr/javasr/produ...id=00952160000
will not mess up the bolt or nut
Old Sep 16, 2006 | 09:57 PM
WHAT TOOL SHOULD IF I BOUGHT THE Craftsman Bolt-Out??? I USED THE OPEN IN TOOL AND THAT WAS LIKE THE ONLY ONE I COULD USE. I CANT GET BEHIND IT WITH A SOCKET RENCH B/C OF THE SPACE I HAVE
Old Sep 16, 2006 | 09:59 PM
Crazy D's Avatar
I'M A REGISTERED USER !!
Do you mean the front or rear sprocket ?
The fronts should be a 10mm . You could probably get vise grips on them .
And the rear , do you mean the nuts on the back side , or the flush mount screws ?
The screws are 6mm allens . And the nuts are 14mm .
Old Sep 16, 2006 | 10:40 PM
The Nut On The Back Side. Its A 14mm
Old Sep 17, 2006 | 12:52 AM
AsphaltAssault's Avatar
AsphaltAssault is an unknown quantity at this point
use the box end and dont put consistent pressure on the wrench ,give it jolts to break it loose.
Old Sep 17, 2006 | 01:04 AM
Crazy D's Avatar
vise grips should work . Or a crescent wrench .
Or drill out the screw and get another at the hardware store .
The stock nuts should have like a nylon lock in them , so if you cant get it loose you could heat it up a LITTLE .... But then it won't re-lock .
It should stay tight though afterwards (enough to get by).
Old Sep 17, 2006 | 11:07 AM
Thanks Bro
jmcclendon87
Jul 20, 2019 10:42 AM
Osider92
California
Dec 23, 2012 11:38 PM
Brett256
Nov 23, 2002 09:28 PM
Big Dad
Oct 26, 2002 05:52 PM
