a few questions for stunting a fiddy
hey im jus wonderin what do you guys like better for stunting a scrape bar or the one with the wheels on it.....also, how do you put pegs on the back of the fiddy? do you have to buy the kit from 50 stunt?
Five636 RIP
Re: a few questions for stunting a fiddy
get the pegs from 50 stunt. they are perfect. Many people use bike pegs, (as do I) but unless u can grind them down short and on an angle. they;ll scrape the pavement.
U just put em in and grind a notch for the chain adjuster..
50 stunts just bolt on! worth it! and they look nice.
I never used a 12 bar with wheels.
The 50stunt rear stunt pegs are the way to go, they have biult in chain adjusters, use the stock axle and are desinged for stunting, and the knurled surface sticks like glue to sneekers. The roller bar is fun to use, but so is a scrape plate, I use both. The roller bar will let you come back to a 12 and ride for hundreds of feet, the scrape plate slows the bike down in a hurry, but is better for learning.
well what do you recomend? cuz im on a budget lol ...what do you prefer and which is more fun?
lol, on a budget better make your own.
I have some pegs I got off ebay for 20bucks. https://www.stuntlife.com/forums/sho...d.php?t=144586
I'M looking to make a bar like this https://www.stuntlife.com/forums/sho...05&postcount=2
Or you can get a 12bar/roller or both from this guy. https://www.stuntlife.com/forums/sho...d.php?t=143020
yeah im currently working on a Reinforcement for the subframe, and you can switch out from a 12bar to a roller bar, and never worry about bending your subframe...and you don't have to remove the rear plastics to swap out the bars...All for $100+shipping (introductory price)
i dont' use 12 bars anymore.. after i watched one slice through my buddies leg, and had to take him for 9 stitches, i decided to cut mine off.. plus the dozens of scars on my legs... pegs are killer, i have 50 stunt ones on mine.. but bike pegs would be fine, just cut an angle in them.. and for subframe support, before i used rebar, and made it from mid 12 bar to the stem of the frame before the swingarm, would nail it 3rd gear hard and NEVER bent the slightest bit
i know what you mean about scars on your legs....i have pleanty of them, but once i got used to it, i hardly bang it anymore...my 12 bar has round edges (no pointy edges) and i have seen buddies hit their heads/break legs/arms don't mean ill quit riding...whats a few stitches
Get the 50Stunt pegs. They are really strong, and also are at a perfect angle. I have a scrape bar. I love it. but it slows you down....alot......fast.I heard the roller is good. Get regular pegs from 50stunt for the front its fun.
i run an FI bar with 50stunt rear pegs, i would also recommend 50 rear brake on the bar kit
i thing scrape plates are the way to go because wheels look f'd up and i think you lose style point
you can always put plastic on the scrape plate and you can slide it longer
