Idle Problems
Old Dec 18, 2004 | 05:22 PM
Seth Gecko's Avatar
Seth Gecko is an unknown quantity at this point
Idle Problems
Hello to all here. This is my first post. I have done alot of searching here and read the carb sticky and I just can't seem to find the answer to my question. First off I have an '01 xr50 with the only mod being the opened air box. My problem started yesterday with the idle. It will idle ok for a while then it will cut off. Also when you rev the bike the idle takes a long time to return back to the idle speed. I am sure that someone out there knows how to fix this. Thanks in advance for the help.
Old Dec 18, 2004 | 08:17 PM
Re: Idle Problems
try lubing the cable and the throttle assembly
Old Dec 18, 2004 | 10:23 PM
Seth Gecko's Avatar
Re: Idle Problems
I have tried that. Thanks for the response. I have been browsing through a lot of threads and I see that you have some good answers. I also noticed that it will rev up a little just out of the blue. I thought maybe I had an air leak but I can't imagine where. I have checked the intake and the throttle boot?
Old Dec 19, 2004 | 07:59 AM
Re: Idle Problems
let it sit there and idle while moving your bars around side to side. if the idle goes up as u move the bars, u will need to loosen the throttle cable adjustment just a tad. if thats not the solution, it could quite possibly be a vacuum leak.
Old Dec 19, 2004 | 08:39 AM
Re: Idle Problems
spray starting fluid or carb cleaner around the intake,carb etc while its running, if theres a leak, when you spray it youll know
Old Dec 19, 2004 | 03:02 PM
Jimbo7's Avatar
Re: Idle Problems
That's a great idea!
I should try that on my ct70, cus sometimes it runs like crap and I know the intake or carb. is at fault.
Old Dec 19, 2004 | 04:13 PM
Z50NATIONALS's Avatar
Re: Idle Problems
now that you have opened the airbox up your gonna need to tinker with the fuel screw .this dictates what your air fuel mixture is at idle
Old Dec 19, 2004 | 06:18 PM
Seth Gecko's Avatar
Re: Idle Problems
I have checked for leaks using carb cleaner and there is no change in idle. I rode for quite a while today and when I would stop it would idle for about 5 seconds and then die. I have been adjusting the air fuel screw to no avail. The bike runs great but just doesn't seem to want to idle.
Old Dec 19, 2004 | 10:21 PM
Re: Idle Problems
just turn your idle up some, when mine was stock it would do that, only idle about 30 seconds and die
Old Dec 21, 2004 | 12:18 PM
Re: Idle Problems
im gonna agre with hurricane on this
turn your idle up 1/4 turn and then reset your mixture screw
gonna take some tinkering be patient
Old Dec 22, 2004 | 12:51 AM
Jimbo7's Avatar
Re: Idle Problems
don't forget to do a plug check after all the "tinkering"
ZaneZatton
Aug 8, 2018 06:21 PM
jbonef4i
Jul 5, 2014 08:55 PM
jbonef4i
Jun 26, 2014 10:46 PM
eblas
Stunting Help and Advice
May 13, 2013 09:07 PM
eblas
May 13, 2013 09:04 PM
