my 50 isnt running...cant wheelie now!
Old Dec 7, 2004 | 05:27 PM
50ccoutlaw is an unknown quantity at this point
My fiddy isnt running good...the park plug boot was cracked so I got a new spark plug boot and spark plug but that didnt fix it . It will go good for a little then start bogging and go..bog down...go a little...then die out and it will be hard to start . same **** keeps happening it will start but dies out in a little...what do u think the problem could be?...Im gonna get some carb cleaner and see if that works....any suggestions
Old Dec 7, 2004 | 06:13 PM
five0addict's Avatar
five0addict can only hope to improve
Re: my 50 isnt running...cant wheelie now!
need some more info,
how did the boot break?
you have good compression?
spark?
ground?
what carb mods?
all motor bolts tightened to specs?
Old Dec 7, 2004 | 06:16 PM
Buick's Avatar
Buick will become famous soon enough
Did you replace the plug when you replaced the cap? If you cracked the cap you probably effed up the gapping in the plug too. If you already did that I've got nothing.
Would I be kicking a dead horse if I suggested proper powerband maintenence?
Old Dec 7, 2004 | 06:35 PM
I didnt touch any of the motor bolts...I didnt mod the carb at all...and it couldnt have anything to do with the new spark plug and boot I just put in becuase its doing the same thing as when the broken spark plug boot was on. I dont know how the boot broke but it wasnt totaly broken just the side had a triangle shaped chip. IDK what else to say.
Old Dec 7, 2004 | 06:36 PM
it has compression and does have a spark
Old Dec 7, 2004 | 06:59 PM
so you take care of it?
airfilter cleaned?
oil fresh?
breather hose not plugged?
you have a cr6hsa or equivelent in ther?
old gas?
i need more info on the bike.. like can you do a plug chop? results?
when did it start?
get it wet?
Old Dec 7, 2004 | 07:26 PM
I change the oil once a month or so....clean the airfilter once a year...lol the manual syass every 600 miles so thats like once a year for the amount I ride. the black hose was tied in a not but I untied it and it still doesnt work. The gas is new. The plug is the right one....I dont know what A plug chop is. It started a while ago and went away..poped up a month ago..now its really bad..its wierd how it comes and goes...really sketchy!!
Old Dec 7, 2004 | 07:37 PM
hey this sounds totally rediculous but i seen a bunch of fiddys do this with the gas in the "on" position. as soon as you would turn it to "reserve" it was fine. switch back to "on", same thing. not sure what causes it, never cared really. give it a shot.
Old Dec 7, 2004 | 07:43 PM
50Pilot's Avatar
50Pilot is an unknown quantity at this point
get a new spark plug.
Old Dec 7, 2004 | 08:29 PM
it has a new spark plug read the first line..
make sure all the hoses are open and clear. HOW ABOUT THE GAS TANK VENT?? IS THAT CLEAR OR TIED UP TOO??
Old Dec 8, 2004 | 01:45 PM
suicidalkings's Avatar
suicidalkings is an unknown quantity at this point
Its called a boot,not a cap,mr.dumass,and a cracked boot would not effect the gap of the plug
Old Dec 8, 2004 | 02:28 PM
Z50NATIONALS's Avatar
yall quit arguing with each other and answer the guys question
a cracked plug cap or boot or what ever you call it wouldnt affect anything unless it got wet allowing the spark to arc off off the head instead of at the plug itself seems to me youve done everything properly by replacing the plug and cap. did you check the gap on the new plug?
i would check to make sure the cap is threaded onto the high tension lead properly other than that your problem may be some where else
and it is called a spark plug cap the rubbers on the ends are the boots
do a urine sample and drain the float bowl into something so you can look at the fuel see if it has tiny bubbles in it or any foriegn materials if it does then you found your problem
Old Dec 8, 2004 | 06:57 PM
make sure the vent is working on the gas tank. if it runs fine at first and then gets worse everytime, crack the gas cap and see if pressure escapes. whats does the plug look like? check the ground wire. try cleaning the carb. also, once it gets to where it wont run, try opening the drain on the float bowl to see how much gas comes out, maybe its not getting gas
Old Dec 9, 2004 | 08:41 AM
Yama50_88 is an unknown quantity at this point
i would take the fuelline off the carb and point it into somthin then turn the gas on and see if it comes out smooth and fast be sure to turn the gas off before u do this and if it doesn't comeout or comes out really slow check ur fuel lines and petcock i got nothin else
Old Dec 9, 2004 | 01:01 PM
Kev900RR's Avatar
mine still runz
Old Dec 9, 2004 | 08:19 PM
ricerocket1135's Avatar
ricerocket1135 is an unknown quantity at this point
sounds to me like you need to clean the carb.... had a jet ski that ran like hell... cleaned the carb and it was a champ again... you have spark so forget about the spark go on to something else.... Try cleaning the carb I think it will help ya.
Old Dec 10, 2004 | 06:55 PM
I took apart the carb and had my freind use a air compresser and blow out allt eh passages...runs perfect now...thanks for the help guys
cbrdoubler
Mar 13, 2023 04:19 PM
nuttz51
Nov 6, 2014 01:30 AM
Stunt Medic
May 23, 2013 10:43 AM
jon t
Stunting Help and Advice
May 18, 2013 11:46 PM
cycle.tim
Feb 24, 2013 08:33 PM
