79 z problems
Old Dec 5, 2004 | 10:56 PM
justahondaman's Avatar
justahondaman is an unknown quantity at this point
79 z problems
restoring my 79 z50 all stock i just put a new top end in it and now it will start and run for about 5 sec and die i put 3 different carbs on it thinking that was the problem but they all did the same things it has good compression. i am lost dose anyone have any sugestions
Old Dec 5, 2004 | 11:57 PM
BLACK DEATH's Avatar
BLACK DEATH is an unknown quantity at this point
Re: 79 z problems
Might be a spark issue. Are you sure the carbs you are using are in working order? Or do they work on another bike at least? My bike would still run even though the carb needed to be rebuilt bad.
Old Dec 6, 2004 | 12:26 AM
Z50NATIONALS's Avatar
Re: 79 z problems
whats the plug look like justin?
black or white?
also check your cam timing/along with your point timing
if you cant figure it out pm me and you can bring it over and we can take a look see
Old Dec 6, 2004 | 10:34 AM
Re: 79 z problems
black or white?
cool i really think it is ign. problems i have the timing set right, but i am not sure what you mean by point timing? as for the plug color it dose not run long enough to get a good reading i am going to pull the fly wheel at work tuesday and clean it really good and see if that helps .
brake cleaner wont hurt it, right?
Old Dec 6, 2004 | 01:09 PM
Re: 79 z problems
OHH man points....
Best advice, let a trained professional set them for you. IF you set them wrong or they are goofed up, the bike WILL not run no matter how bad you want it to. Thank goodness for CDI...
Old Dec 6, 2004 | 03:36 PM
Re: 79 z problems
contact cleaner is fine justin
points are easy
not as easy as cdi heheheheh
set your gap first .0013 (business card thickness if you dont have a feeler gauge) then set the point to open at the f mark
did you check the cam timing while you were looking
an old cam chain will give you the same symptoms of bad timing check and see where it is at and see how much slop it has
Old Dec 6, 2004 | 04:05 PM
Re: 79 z problems
.013 z50NAT. .0013 is thinner than a sheet of paper.
sorry to correct u. just dont to screw anyone up.
Old Dec 7, 2004 | 08:39 PM
BelliSSimO's Avatar
BelliSSimO is an unknown quantity at this point
Re: 79 z problems
you might need new points because mine did what yours did a couple times (starts and runs for 5 seconds then die)before the spark finally disappeared. also if your points havent been replaced in a long long time it might be a good idea to replace those.
also points gap is easy to set just turn the flywheel a little past the F mark to where the points are open the most, and this is where you wanna take the gap measurement from.
oh yeah, use a feeler gauge like fab said, i don't believe a business card is too accurate
Old Dec 8, 2004 | 02:46 PM
Re: 79 z problems
yep my bad fab
.013 which is the same thickness as a business card,but feeler gauges are cheap at the local car parts store i would recommend buying one if you have points and you need them to adjust your valves too so a handy lil tool to have
more than likely justin if the points are right the condensor is bad
that will cause an irradict spark and do like you say its doing
bring it by if you dont get it figured out
--*CBR*KING*--
Apr 5, 2022 11:42 AM
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
