kleen air on my 636-good idea!
Old Jan 21, 2007 | 03:00 PM
Vetter's Avatar
Squid Extradoinaire
Re: kleen air on my 636-good idea!
good link. bookmarked it!
Old Jan 21, 2007 | 03:12 PM
hhmm i wonder if puting the breather to the clean air doesn't act like an evacuation system on a drag car ??
on a car it causes a slight vaccum in the crank case witch means there is no pressure in the crank case for the pistons to fight when going down ..
it is a proven hp gain , not huge but still it's a gain none the less , may be on a bike it would be more noticable due to the power to weight ratio...
the reason for the factory system to go to the air box is purely for emmisions from the crank case to be burned in the combustion chamber and not just vented like it would be in this mod...
ima doit.................................
Old Jan 21, 2007 | 03:24 PM
hyperryder's Avatar
hyperryder is an unknown quantity at this point
wats up terd J/k. that would also mean that the idle would be stronger corect.
yep..
Old Jan 21, 2007 | 03:33 PM
THORPE's Avatar
Thread Killer!!!
THORPE is a decent person
It deff made my idle stronger.
To me It's alot cooler to be able to cut the idle down to near stock sound and still pull smoothe idle tricks. It pulls like a tractor now...but smooth
Old Jan 21, 2007 | 04:34 PM
John LegionST's Avatar
Yes it will (at least it did on my gixxer) change the crankcase from being slightly pressurized to a vacuum
QUESTION: On the 636, the tiny tubes that come off the KLEEN system and run to the throttle bodies, do you cap those off or ?????? thanks!
Old Jan 21, 2007 | 04:41 PM
hyperryder's Avatar
do you have a stock exhaust or after market one
Old Jan 21, 2007 | 04:42 PM
babyJOKER's Avatar
babyJOKER is an unknown quantity at this point
i think u supposed to capped those off
Old Jan 21, 2007 | 04:43 PM
I dont really feel a difference between stock and slip-on on the 636...
Got it figured out, which lines to remove and what to plug. Now i have to figure out what to use as plugs, autoparts store closed...
Old Jan 21, 2007 | 04:44 PM
Originally Posted by MILTOWN BIG OP
is this the one u looking for ?
Thanks bro, took a look at my bike and read that article carefully, got that all figured out now...
just need to find things to use as caps! lol
Old Jan 21, 2007 | 04:54 PM
if you cant find regular vaccum caps you can just put a screw in the end of a peice of vaccum line....
the ones you took off maybe , or just t them together it does the same thing
Old Jan 21, 2007 | 04:57 PM
Screw in the end of a piece of line... i have that! oooooooo, roger, u so smart! lol thanks!
Old Jan 21, 2007 | 05:02 PM
  #33
hahaha i been a riggin a long time
Old Jan 21, 2007 | 05:04 PM
  #34
me too, just havent worked on the old piece in a few months... need to get the riggin part of the brain going again
Old Jan 21, 2007 | 05:05 PM
  #35
use it or lose it....lol
Old Jan 21, 2007 | 05:07 PM
  #36
HAHAHA, yep, damn winter
Old Jan 21, 2007 | 06:08 PM
  #37
THORPE's Avatar
Thread Killer!!!
Yeah I got stock exhaust on mine right now.
And, Sorry I forgot to mention the caps on the throttle boddies. Yeah cap them i got lucky parts store had caps but I had to use a bolt in the end of the 1/2" line on the back of the airbox cause they didn't have a cap that big.
When you get into it its not a complicatd as it looks.
Anybody else done it yet and tried it besides Edlegion?
I'm curious what everybody else's results were
Old Jan 21, 2007 | 06:09 PM
  #38
Scotty7one7's Avatar
hey john...on my gixxer i just put a filter rite out of the crankcase and capped the airbox...was that stupid or smart....whats teh correct way to kep oil from going to the air box....not that im dragging now becuz i got a round bar...but just for assurence ..thankx alot...
Old Jan 21, 2007 | 08:03 PM
  #39
midnitesins1196's Avatar
midnitesins1196 is an unknown quantity at this point
does anyone know if this is close to the samething on a 04 R6, and does anyone have pics
Old Jan 21, 2007 | 08:29 PM
  #40
stickler69420's Avatar
stickler69420 is an unknown quantity at this point
i just did this but i did not do anything to the throttle bodies do you have to or just cap the one little vacum line that comes off the kleen system
