954 Brake Problems Help!!!
Old Jul 5, 2004 | 02:03 PM
Posterchild's Avatar
Posterchild is an unknown quantity at this point
OK this is wierd i crashed and the fitting that the tube from the resevior for the front brake broke so i raplaced the fitting into the master and filled with new fluid and bled like a 10000 times no bubbles. When the bike is sitting there it has good brake lever but if i move the bike like 2 feet i have to pump the handle to get pressure again its stupid. I know this is sually what happenes when you have a bubble in the system you get spongy handle. I have beld so many times. There aer no leaks either in teh whole system. ANYONE HELP ME PLEASE !!!!!!!!!!
Old Jul 5, 2004 | 02:27 PM
KungFu954's Avatar
KungFu954 is an unknown quantity at this point
Re: 954 Brake Problems Help!!!
Ok,
First forget that the symptom happens when the bike moves ok because the system is independant which means that the brake will work without even being attached to the bike. There is no doubt that there is air in the line. Sometimes,,actually most of the time, bleeding can be a serious pain in the ****. You might have a leak in the system as well. So test that out.
But if you bleed the brakes a couple times and there is still some fade then drain the system and repeat, also make sure your useing DOT 4 and DO NOT GET IT ON THE PAINT OR PLASTIC. Lockhart makes an easy bleeder which is just a different fitting (they are cheap) I haven't used one but I have heard good things about them. Check the pressure in the lines. ALSO, did you replace the banjo crush washers, cause if you didn't that is your problem.
Try those things and post back,,,I'll do my best to help you out.
Old Jul 5, 2004 | 02:33 PM
phatboy's Avatar
phatboy is an unknown quantity at this point
check and see if your rotors aren't bent that sounds like a bent rotor to me but im no professional
Old Jul 5, 2004 | 03:04 PM
KungFu954's Avatar
True,,,didn't think of that.
Old Jul 5, 2004 | 10:57 PM
teva's Avatar
teva is an unknown quantity at this point
Had The Same Problem On My Older 900rr. It End'd Up Being A Bad Master Cylinder. The Ring Inside It Was Bad And Was Not Keeping Pressure In The System. Changed It And Everything Worked Fine. Mine Gave Me The Same Bleeding , That Yours Is Giving You, Solid Fluid, So I Thought It Wasn't It Too. Hope This Helps.
Old Jul 5, 2004 | 11:02 PM
Hmm i never did change my crush washers ill do that and then try the master cylinder. Why would a bent rotor cause this my rotor isnt bent but im just curious?
Thanks for all the help guys this is why i love this site peeps helping out.....
Old Jul 5, 2004 | 11:07 PM
standy's Avatar
LAWN JOCKEY
standy is a decent person
I would bet that you have a bent rotor.....when you push the bike forward, the bent part of the rotor pushes the pistons back into the caliper. That's usually the reason why you have to pump 'em up again to get a good lever feel.
Old Jul 5, 2004 | 11:15 PM
The lever looses pressure even when the bike doenst roll also if you leave it for ahwile
Old Jul 6, 2004 | 01:03 AM
wheeliesnshit's Avatar
wheeliesnshit is an unknown quantity at this point
yeah check you rotors dude might be bent ?? but more important bleed that fuka from the master rather from the calipers master first then calipers ... sounds like you have air in your master bleed it from the bolt and let me know how you make out .. and as far as the bajo washers ahahahahahahahahahahaha as long as there not cracked and pissing all over tell that dude he's a reeege and they make mmi schools for ill mind like that hahahahahahahahahahaahah
Old Jul 6, 2004 | 01:06 AM
no leaks anywhere i will bleed the **** outa of it tomrrow
should i bleed the master from where the brake line connects to it???
Old Jul 6, 2004 | 01:15 AM
Ishc54's Avatar
Ishc54 is an unknown quantity at this point
You should bleed it form the top and bottom ...
Old Jul 6, 2004 | 01:17 AM
yup top and botom !! absolutly from the master where it connects and then both caliper ,,,, furthest one first
Old Jul 6, 2004 | 01:24 AM
hmmmm never bled the master will work on that tomrrow and check back
thanks guys
Old Jul 6, 2004 | 01:29 AM
nymm hari is an unknown quantity at this point
my buddy had the same problem on his 636. between the dealer and him they bled the brakes 5x and the same result kept coming up, no brake pressure when the bike is moving. one of his rotors ended up being out of round it was about 25mm off from being true and had a hair line crack. luckily kawi replaced the rotor under warranty. and his bike was never in a crash.
Old Jul 6, 2004 | 03:25 PM
Right Rotor Bent Pretty Good Wheel Doesnt Even Spin Freely!!!!!!!
I Need New One Anyone Got One???????
Old Jul 6, 2004 | 10:51 PM
I Need A New Rotor Anyone Got One ????????
Old Jul 7, 2004 | 10:57 AM
http://cgi.ebay.com/ebaymotors/ws/eB...category=35592
i found 2 for you on feebay, good luck you can also try www.1000rr.com
dangerdan
Jul 4, 2013 04:23 PM
simp750
Nov 12, 2012 11:50 AM
DhGSXR600
Nov 7, 2012 05:54 PM
greenhornet347
Oct 15, 2012 02:26 PM
Pete_SOI
Oct 11, 2002 01:43 AM
