spark plug replacement help
Old Jun 26, 2004 | 09:11 PM
paul600f3's Avatar
paul600f3 is an unknown quantity at this point
need help changing the plugs on my f3. is the correct and/or only way to remove the side fairings and shove my fat hands into the small space between the engine and the frame.
Old Jun 26, 2004 | 10:14 PM
Frogger's Avatar
Frogger is an unknown quantity at this point
Re: spark plug replacement help
i think you can get to them easier if you pull the tank and airbox off, but i don't rightly know.
Old Jun 26, 2004 | 10:40 PM
aNskY's Avatar
aNskY can only hope to improve
i did it that way paul (shoving hands in that tiny space)
Old Jun 30, 2004 | 09:34 AM
paul600f3's Avatar
nope tried that first, carbs and frame are in the way.
Old Jun 30, 2004 | 09:37 AM
paul600f3's Avatar
i'm gonna do that, maybe i gotta borrow someones kid or a midgit
Old Jun 30, 2004 | 12:06 PM
Frogger's Avatar
ah, i just ride an F2, I have never pulled one apart. Just seemed logical, lol.
Old Jun 30, 2004 | 12:35 PM
Ice Mike's Avatar
Old School
Ice Mike is an unknown quantity at this point
If its like every other 4 cylinder, just pull up the gas tank, remove the air bix, use a plug socket and extention. should take about 20 min.
Old Jun 30, 2004 | 02:54 PM
teva's Avatar
teva is an unknown quantity at this point
IT'S ALOT EASIER TO YANK THE TANK,AIR BOX SO YOU CAN GET IT FROM UP TOP. THERE SHOULD BE A BAR FROM LFT TO RGHT JUST ABOVE THE AREA YOU NEED TO WORK ON. JUST GET 2 - 2'' 3/8'S EXTENTIONS SO YOU CAN FEED THE FIRST ONE DOWN,THEN SNAP THE SECOND ONE ON TO PUT YOUR RACHET ON. IT'S FUN... TAKE YOUR TIME THAT WAY YOU ONLY DO IT ONCE...
Old Jul 1, 2004 | 02:12 AM
HavokCycle's Avatar
HavokCycle is an unknown quantity at this point
may need a extension with a knuckle in the middle to reach the outer two, i ALMOST need one for my gix, i can barely reach them.
but why would the carbs be in the way? i'm not an expert on hondas but if its like damn near every I4 the plugs should be in the middle of the valve cover and carbs on the rear of the head
Old Jul 1, 2004 | 09:22 AM
paul600f3's Avatar
carbs and airbox, but the engine is also angled forward
7EVENTY7
Jul 29, 2014 01:38 PM
s14nismo
Mar 26, 2014 01:04 AM
McLovinRR
Jul 24, 2013 06:19 PM
knowlzy0791
Apr 13, 2013 07:32 PM
knowlzy0791
Mar 19, 2013 10:57 PM
