I NEED HELP. front sprocket won't come off...
Old May 13, 2010 | 01:54 AM
MisterEdd's Avatar
MisterEdd is a decent person
ok so i picked up my new sprockets and chain. for the life of my i cannot loosen my front sprocket. i have a 04 636 . i flattened the washer like the service manual says but the nut will not come loose. i even tried with the torque wrench went all the way to 150 foot lbs. did i miss something? help me pleaaasee even any suggestions. i sprayed it with wd40 maybe its stuck i dont know. im doing the chain and rear sprocket now hopefully someone has advice by the time im done with this...
Old May 13, 2010 | 02:00 AM
StrictlyStunt's Avatar
Re: I NEED HELP. front sprocket won't come off...
Old May 13, 2010 | 02:20 AM
MisterEdd's Avatar
yea. unfortunately i intelligently left my impact with dad. and he lives to dam far lol
Old May 13, 2010 | 03:56 PM
hondaruss's Avatar
hondaruss is a decent person
Put a bar in the rear rim spin it let it catch on the swing arm, and break it loose ..
Old May 16, 2010 | 12:16 PM
joeyzaza's Avatar
joeyzaza is a decent person
You probably have it off by now, but I'll add how to do it, for anyone else reading.
Leave the rear wheel, chain, and sprocket on. Get to the point of removing the front sprocket nut. Make sure the bike is in neutral, and stand on the rear break. Don't use a torque wrench, instead a breaker bar or pipe. It will come off! Get a buddy to help you if you cant get it by your self. Righty tighty, lefty loosy. Good luck, those things are torqued on there really good.
Old May 16, 2010 | 01:53 PM
ya if you dont have a good impact then leave the bike in gear and hold the brake at the same time and use a big breaker bar , the locktite they use is awesome ..lol
Old May 16, 2010 | 02:33 PM
danny__darby's Avatar
danny__darby is a decent person
i struggled getting mine off on my 05 zx6 i ended up using a breaker bar on it,wouldnt come off at first tried putting some heat on it to break up the loctite as a last resort didnt see it working being steel on steel but heat went on breaker bar turned bit of gental persuasion and bam its off,thats how it worked for me=)
Old May 16, 2010 | 02:44 PM
you have to be very careful using heat that close to the seals , i would take the bike to a tire shop and ask them to blast the nut off with a 3/4 impact before i would use heat on it ..
stuntin'_cbr
Nov 20, 2024 11:08 PM
frayz
Mar 24, 2013 08:11 PM
gsxriders
Feb 5, 2013 11:25 AM
Jay Rodriguez
Dec 6, 2012 09:27 PM
Clint Ewing
Nov 30, 2012 09:06 AM
