brake control help
Old Jun 23, 2003 | 10:35 PM
streetassault's Avatar
streetassault is an unknown quantity at this point
brake control help
need some imput on brake control during twelves? can scrape and ride it no problem but my brake control is spotty .. would like any imput as far as when you guys are applying and how much .. that sort of thing .. thanks
Old Jun 24, 2003 | 06:07 PM
PavementEater's Avatar
If your asking when we are applying our brake, wouldn't you know from scrapin? I start out with mine pressed, even before I clutch it up to 12..
practice makes perfect.
Old Jun 24, 2003 | 06:27 PM
im having trouble with throttle and brake control while sustaining a good 12 or i guess just smoothing it out
Old Jun 25, 2003 | 04:09 PM
Lb3's Avatar
Lb3
me too. I keep getting in a brake throttle tug of war. I have a complete lack of feel for the brake unless I press it hard and hold it. It seems like it helps alot when I mash the brake kinda hard and just hold it and use the throttle to control height. That takes all the jerkiness out of the throttle but I am wondering if that is the wrong thing to do.. I dont know. I dont know. I dont know.. aaaah! It seems like I would ruin my rotor/pads real quick doing that.. Not that I really care anyways cause my bike is crap. My big problem is that my brain is trained to let off the damn gas when I get too far back so I end up gassing it back and getting on the brake and then letting off the gas while holding the brake and gassing it back again and blah blah. Habits die hard. Guess I just need to practice. :P
Old Jun 25, 2003 | 06:48 PM
d-acesDan's Avatar
D-Urban
d-acesDan is an unknown quantity at this point
turn your idle up, and just use brake control. then, many things happen, no handers, or no throttle hand.
Old Jun 25, 2003 | 06:58 PM
CRAZY DAN's Avatar
A Few Loose Screws - DVD
CRAZY DAN is a decent person
yup yup
changed the gears and turned up the idle and those tricks basiclly fell out of the bag!
Old Jun 25, 2003 | 11:44 PM
Lb3's Avatar
Lb3
I will give that a go tomorrow. Hey Dan, what gears are you runnin man? Another problem that I am having (but making slow progress on) is getting used to how twitchy 1st gear is now. I have a gsxr 600 but put a 750 motor in it two weeks ago so I am having to learn my bike all over again. To complicate things further I wasnt able to change gearing from what I originally had on my 600 which was -1 in the front and +2 in the back which is -2 +5 with a 750 motor. Is -2+5 maybe too drastic for an 02 gsxr 750?
Old Jun 26, 2003 | 06:46 PM
d-acesDan's Avatar
D-Urban
I have - 2 in front and +8 in back on my 900rr
stuntin'_cbr
Nov 20, 2024 11:08 PM
Kerns BBO
Apr 29, 2013 12:34 PM
ProzaK
Reckless Methods
Nov 14, 2002 10:49 PM
work765
Oct 29, 2002 05:54 PM
