glowing headers/oil cooler
Old Nov 30, 2007 | 07:47 PM
bobbybrownnose4's Avatar
bobbybrownnose4 is a decent person
my 04 GSXR 1000 yosh pipes are glowing red ever since i installed my power commander. oh yea and my oil cooler is leaning up against the headers and it melted a portion of the cooler and now it leaks... i tried repositioning the mounting oil cooler brackets...is there anyway to run the bike without the oil cooler? i can't see how much cooling an oil cooler will do if it is used on a stunt bike
Old Dec 2, 2007 | 01:46 AM
Danger_Dave's Avatar
brabuhburbuh
Re: glowing headers/oil cooler
yes you can run the bike without an oil cooler. and the red hot pipes are due to a lean condition. you might want to tweak your power commander a little bit or maybe try downloading a different map. not all bikes are the same and those maps that you get off the cd or internet are just a rough estimate.
Old Dec 5, 2007 | 04:11 PM
Outlawtorn50's Avatar
Outlawtorn50 is an unknown quantity at this point
Yeah, as mentioned above, glowing red pipes means you're running lean as hell. You're gonna want to adjust that before it causes damage.
Old Dec 15, 2007 | 07:39 PM
what the **** should i do
Old Dec 27, 2007 | 08:33 PM
E-Loc540's Avatar
540 BOYZ SUMO STUNTER
E-Loc540 is an unknown quantity at this point
yeah your too lean like mentioned in the other post....I guess you could remove the oil cooler but it is on there for a reason.....it does help lower themps which may not be a big deal up north....your power commander instructions should tell you what to do about adjusting the fuel air ratio
Old Dec 28, 2007 | 11:43 PM
Reckless01's Avatar
Yea...I got that!
Reckless01 is a decent person
oh you have a PC? I didn't hear that in the orig post. Yea lean could be the problem for sure then. I thought you were talkin stock bike! What about the milky oil? Figure that out yet?!
gman86
Dec 30, 2014 09:25 AM
punisherzx12r
Jun 5, 2004 12:07 PM
Timmy30
Vertical Mischief Crew
14
Jun 2, 2004 02:20 PM
Bluto
Detroit Street Ryders
Dec 23, 2002 06:56 PM
