Mount crack problem...
Old Dec 30, 2006 | 12:02 PM
bruno_z's Avatar
I was building a cage yesterday and got the right mount bolt out where slider was to put mounting point and when I put it back on it went in hard and the inner tip of the mount broke...when I got the bolt out I saw it was bent little bit (I guess from a crash) and that fu(ked it up...it's not a big piece but Im affraid it might be weaker now...the original bolt doesn't even go that far in (just little before the crack), and it's the same for slider bolt I had...
A guy that welds engine blocks and stuff like that profesionaly saw it and he said it shouldn't be a problem because there's plenty of it left, but I wanna hear what you got to say? I made a mounting point for a cage with a plate so it bolts on there but the point of impact above at the frame so there shouldn't be much stress at that point but...here's a pic...
Old Dec 30, 2006 | 12:08 PM
da Liks's Avatar
da Liks is a decent person
Re: Mount crack problem...
i think it'll be fine!
Old Dec 30, 2006 | 12:47 PM
bruno_z's Avatar
hey Alex, check your pm's...I used your design, a bit modified but basically that's it!
Old Dec 30, 2006 | 12:52 PM
da Liks's Avatar
send it again, my pmbox was full!
Old Dec 30, 2006 | 06:03 PM
Paky's Avatar
Paky is an unknown quantity at this point
shity bike
Old Dec 30, 2006 | 09:13 PM
Snipes20's Avatar
just ride it till it breaks and then weld it back on
Old Dec 31, 2006 | 04:10 AM
bruno_z's Avatar
think I'll do that!
@paky: I can help you make your just like mine...it's not the bike, it's an idiot that forced that bolt in...
Old Dec 31, 2006 | 04:19 AM
make sure you put a spacer in to take up that gap and i would get a bolt that goes all the way through....but just not too long
Old Dec 31, 2006 | 05:47 AM
bruno_z's Avatar
yeah, I got that spacer, thanks!
WickedJ
Jul 28, 2013 12:13 AM
zoniebutt
May 1, 2013 02:50 AM
Kerns BBO
Apr 29, 2013 12:34 PM
sbeltinc
Dec 19, 2012 01:22 PM
qfo
Nov 15, 2012 10:39 PM
