oil filter will NOT come off
Old Oct 23, 2005 | 01:15 PM
rtpassini's Avatar
rtpassini is an unknown quantity at this point
Re: oil filter will NOT come off
Originally Posted by martino
nah man, theres a tool just for that.. its got 2 jaws that tighten as you crank on it. you put it on the end of a ratchet, and the more you loosen it the tighter the grip.. best part is, it goes straight on so you can access it no problem through the headers.
pics? links? or a name or something?!?! that would be awesome to have that!
Old Oct 23, 2005 | 01:35 PM
Squidmark's Avatar
Squidmark is an unknown quantity at this point
k. after reading some threads on different boards, alot of ppl agree with the suggestion of going at it with a sharp chisel. So try that first. Basically what happened is that it got overtightened, got hot, the rubber squeezed itself into places it normally wouldnt go, and basically melted onto the various surfaces. remove the outer tin-can shell of the filter, and the filter element. Wedge that chisle between the plate and the filter to try and break the rubber seal loose. What I like doing is getting pissed at it and just start hitting it harder, somthing will let go. Either the hammer will hit your hand, the chisel will break, the chisel will slip and go through a thin aluminum oil pan wall, the filter will come off, or a combination of the above. Other ideas are cutting away the can, and making a tool that fits into the holes that you can rotate it with. (think of the 2 pronged tool thing you use to change the discs on an angle grinder)
or just buy this and be done with it.
http://www.aircraftspruce.com/catalo...filtertool.php
good luck
Old Oct 24, 2005 | 08:33 PM
martino's Avatar
wheres all the fat girls
martino is a decent person
haha heres a pic
i got one, same concept but better.. 6 bucks at pepboys like 10 years ago. this happened to be on ebay for 8.50 buy it now.
Old Oct 24, 2005 | 08:46 PM
Danger_Dave's Avatar
brabuhburbuh
take that screwdriver. insert into gas tank to poke hole. buy 2 feet of canon fuse. insert. light. run. get a gixxer......
Old Oct 25, 2005 | 04:16 PM
Schwartz's Avatar
Schwartz will become famous soon enough
I'd take the Header off because it's being so hard and the outcome of not getting this off right is Grim.
I'd say use heat but man around that oil!?!?!? Yeah.
Slot the side of the filter with a chissel or screwdriver then use a flat head and a hammer to break it loose. *** I hope you get it off ok. What a drag something so simple being such a Bit ch.
STUNTGSXR
Jun 13, 2014 02:36 PM
Clint Ewing
Dec 18, 2013 03:51 PM
kystunt
Sep 30, 2013 01:31 AM
McLovinRR
Jul 24, 2013 06:19 PM
chadm
Dec 4, 2002 08:57 AM
