HELP!!! Engine block problem.....PLEASE LOOK
Old Oct 20, 2005 | 07:36 PM
Tdeal28's Avatar
Tdeal28 is an unknown quantity at this point
Here is the deal.......
I was putting on the rest of the parts that I need to get my bike back and running and when I took off the stator cover I noticed that there was a crack in the engine case right below one of the bolts.
The crack is about a half an inch long. What if anything has anyone done to seal up the crack so oil doesn't leak out???????
I was told by someone who worked in a industrial foundry that they have seen crack sealer where it leaks down into the crack then hardens to help seal it. Does anyone know where I can find something like this??????
Old Oct 20, 2005 | 07:41 PM
NINER's Avatar
Retired
Re: HELP!!! Engine block problem.....PLEASE LOOK
I was told by someone who worked in a industrial foundry that they have seen crack sealer where in leaks down into the crack then hardens to help seal it. Does anyone know where I can find something like this??????
Clean all the oil off with carb craner and put some JB Quick on that ****. JB Quick is a member of the holy trinity of stunter repair methods: zipties, ducttape, and JB Weld.
Old Oct 21, 2005 | 10:09 AM
kawibikelover's Avatar
kawibikelover is an unknown quantity at this point
unless you want to go to all the trouble to get it welded i would jb it it worked for a wreked 929 i fixed and it hust wasnt a crack the whole part of the block about a square cm broke off
Old Oct 21, 2005 | 01:12 PM
f4rider's Avatar
I'm also a big fan of jb quick, but for something like that i would recomend the the origional stuff that takes a day to cure. According to the jb weld website, jb quick is about 1/2 as strong and about 1/2 as heat resistant compared to the origional stuff. The origional stuff is what people have used to fix axles and stuff like that.
Old Oct 21, 2005 | 01:20 PM
NINER's Avatar
Retired
I'm just impatient.
Old Oct 21, 2005 | 03:13 PM
Tdeal28's Avatar
Looks like I will be JB Welding it.......now I just have to wait until Wilma (Hurricane) passes through and hope my bike is still here..........
Old Oct 21, 2005 | 03:24 PM
DoodleF4i's Avatar
remember jbing it wont stop it from cracking any more if you crash it again..just keeps oil from passing thru
Old Oct 21, 2005 | 04:22 PM
SAMBO's Avatar
I had the same problem on my 929 but it was worse. I high sided a fast seat stander circle and my cage pushed in so far that the impact on the crash was assorbed by my left stator/magneto case cover. When i took the case off, a triangle that was 1 inch long in all directions fell off the block. And it happend to be where one of the mounting bolts goes through.
All i did was drain the oil, clean all the oil in the block, i put jb quick on the inside of the motor, in the middle of the crack and on the outside. Hasn't leaked and its been a month. Jb quick prevails once again!
Old Oct 21, 2005 | 04:54 PM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
Weld It If You Want It To Last.tow It To A ****in' Muffler Shop Or Something And Shoot Them A $20 And I'll Bet They Will Do It
Old Oct 21, 2005 | 05:32 PM
Wheeliest's Avatar
Scrapes Elbow
****in real doggy
Old Oct 24, 2005 | 12:03 AM
Danger_Dave's Avatar
brabuhburbuh
dude. f*ck jb weld. go to alumaloy.net or go on ebay and type in alumaloy, i've used this stuff and it works outstanding, its so incredibly easy to use and turns out to be so rock solid and stronger than welding. i hit a median doing a stoppie 6 months ago and completely busted 2 ears off of the block part that the case bolts into same situation as you, but worse. all you need is a propane torch to melt this stuff on and its rock solid, i custom fabricated 2 new ears and then drilled em, tapped em, and sanded em. i welded my foot shifter with this stuff too! they also make cast and steel versions of this stuff, you cant go wrong, it f*ckin works.
Old Oct 24, 2005 | 12:19 AM
Wheeliest's Avatar
Scrapes Elbow
does it bond easy to aluminum? i tride useing some **** awhile ago just like it to repair a clutch lever and **** wouldn't bond to it at all, plastic weld did better...
Old Oct 24, 2005 | 12:26 AM
Tdeal28's Avatar
I came across that alumaloy stuff and it looks just like you are soidering....but if you say it works maybe I will give it a try.
Old Oct 24, 2005 | 12:30 AM
Kaotic's Avatar
Kaotic is an unknown quantity at this point
my boy was telling me about that alum **** over the summer saying he saw a commercial... that stuff really works? if so i'll have to try that crap
Old Oct 24, 2005 | 12:33 AM
brabuhburbuh
yeah i was amazed. its something that belongs in every stunters garage.
Old Oct 24, 2005 | 01:41 AM
jowalskiMO's Avatar
jowalskiMO is an unknown quantity at this point
yeah i have seen it, it works pretty goos, basically some AL type filler with epoxy resins, same idea as JB weld, but with heat, and wayyyyyyyyy quicker set up. It is not stronger than welding, no way in hell. welding alters the crystalline strusture of the metal, to form the two pieces into one, instead of adhering them together. jb weld or the aluminum **** will work fine in this situation, but i would trust jb weld, because its cheap, easy to get fast, and proven. who knows how the aluma **** might be with oil, and what if it detiorated and flaked off into your motor
Old Oct 24, 2005 | 02:20 AM
rtpassini's Avatar
rtpassini is an unknown quantity at this point
all i know is this...
i used to think the things i did with my car were ghetto....
but you guys always talking about jb welding things really makes me feel better about my stuff. lol
Old Oct 24, 2005 | 12:31 PM
Tdeal28's Avatar
I found this stuff called HTS-2000 (its very similar to the alumaloy). I emailed the company and according to the the temp range is good to 730deg. and will withstand oil.
http://www.newtechnologyproducts.net...num_repair.htm
I guess my main concern is that when my 954 is at full temp I know for sure that the engine case is dam Hot, **** my frame get so hot in the summer that if I touch my legs to it when I am riding it hurts......I would be afraid of the soldering stuff starting to break up alittle or melt........
Check it out and let me have some of your opinions.............Please!!!
busa4
Jan 31, 2014 10:20 AM
DJPlayer
Sep 26, 2013 08:54 AM
JFLACO610
Jul 25, 2013 06:27 PM
Stupid-Stoppie
Jun 4, 2013 09:54 PM
SlitZ
May 6, 2013 06:24 PM
