Fuel Problem with my CBR600 F2 :( Plz someone help me :)
Old Jun 20, 2005 | 04:17 AM
wheelie*zip's Avatar
wheelie*zip is an unknown quantity at this point
Hi there,
I bought a cbr600 F2 from '92 and when I do Balance point wheelies, or further, the engine doens't get enough fuel... And then 1 cylinder falls away and the engine runs on the other 3 cylinders...
That makes it impossible for me to do good slow wheelies
I don't have this problem when my dented tank (about 10 Liters) is full with gas... When it's totally full, i don't have this problem... But when there is only 9 Liter left, the problem appears
Do all the F2's and F3's have this problem ? E-dub from team OM, how do you do it ? Or don't you have this problem ?? Cause he rides a F3 right ?
Is there anyone who can help me ? Cause some people say I need other carburators, or a fuel pomp, but I don't know if that's going to help...
I hope someone can help me,
greetings, a desperate Dutch wannabe stunter
Old Jun 20, 2005 | 05:02 AM
)>>abc<<('s Avatar
)>>abc<<( is an unknown quantity at this point
Re: Fuel Problem with my CBR600 F2 :( Plz someone help me :)
Sounds like your floats might be off or something... I'm pretty sure you can set the floats to give it more fuel, yours might just be set really low, therefore not enough fuel when vertical. 12's will always be a bit of a problem with carbs, but as long as they're set right B.P. wheelies should be cake.
Old Jun 20, 2005 | 08:14 AM
You gotta keep your tank full all the way. Or get an inline fuel pump off an F3, then you'll only need to keep your tank 2/3 full.
Old Jun 20, 2005 | 08:43 AM
So it has nothing to do with my floats ?? Other idea's ?
Old Jun 20, 2005 | 05:06 PM
Judd's Avatar
Murder Mitten takeover
Judd is a decent person
yea, just keep the tank full, when the bikes vertical the gas level has to be above the carbs to keep gas flowing to it.
Old Jun 20, 2005 | 11:33 PM
tuquick4u2's Avatar
tuquick4u2 is an unknown quantity at this point
i have a 97' f3, but my engine doesn't shut off or sputter untill i set it back down, then(if its past the BP for a while) it almost always shuts off. is there anyway to relocate the fuel delivery. i would think if an extra line was directed toward the seat it would suck up more fuel. any other ideas?
Old Jun 21, 2005 | 04:13 AM
Yeah, how does e-dub do it ? And there must be other stunters around here with F2's or F3's who has there own solutions...
Old Jun 21, 2005 | 03:55 PM
I never found it to be a hinderance except for bar tricks.
Old Jun 21, 2005 | 05:40 PM
Dutch boy's Avatar
Dutch boy is an unknown quantity at this point
he keeps his tank full,
hun rijden met de auto naar de locatie en bij zich hebben ze benzine
stunten dan tanken dan stunten en dan tanken
maar hij heeft een F3 dus kan je net wat langer doorrijden
Jur jij gelooft mij nooit he
Old Jun 23, 2005 | 03:55 AM
simpson's Avatar
simpson is an unknown quantity at this point
I ride Cb600 Hornet and I've got this same problem. I don't want to play with carburators, so I'll try modify it this way, if it work I'll tell
I've got problem with oil lubrication too. Do I have to modify sump or I should only put more oil to engine?
Old Jun 23, 2005 | 10:24 AM
Originally Posted by simpson
I ride Cb600 Hornet....I've got problem with oil lubrication too. Do I have to modify sump or I should only put more oil to engine?
Run a little extra oil, 1/4 to 1/2 a liter. You can also turn your oil pickup around which will move the opening about 2 cm to the rear.
Old Jun 25, 2005 | 04:19 PM
E-DUB OM's Avatar
AGGRESSION!
E-DUB OM is a decent person
F2's dont have a fuel pump on them. F3's have a little fuel pump which isnt the best but it helps. On my F3 I just try and keep the tank full to the top. It runs just fine. I havent had any problems. On the F2's we tried putting a inline fuel filter which helped a little. Ive also heard that you can poke a hole in your gas tank and it will run like a champ. Just like when your pouring gas. If you pour it out of the container with the breath valve closed the gas comes out slow. Throw some air in that sucka and it shoots out. I havent tried that one yet though.
I would try and get a F3 fuel pump and rig it up. You should be good to go with just that
E
Old Jul 3, 2005 | 05:41 AM
Thanks for the info man !! :YEAH But where should I make a whole in the tank ? And how do I make sure no fuell will come out of it but at the same time, air is running in
Old Jul 3, 2005 | 04:19 PM
anyone ??
By the way, today I transformed the tube from my fuell tap (the tube that goes into your tank and is for the "normal" gas stand, not the reserve). I bented the tube 90 degrees, so when i do a high wheelie, the tube of the fuell tap points down and can still suck up gas out of the tank.
Maybe this will help also ???
Old Jul 5, 2005 | 02:43 PM
KICK
Old Jul 11, 2005 | 09:50 AM
CLUNKER's Avatar
CLUNKER is an unknown quantity at this point
you can drill a small hole in the tank and secure a check valve in the hole. the check valve will make it so air can go into the tank but nathing can come out. ive put a little thought into this and i think this is what im going to do on my 97 f3.
Old Jul 13, 2005 | 08:17 AM
simpson's Avatar
I tried riding with full tank, but it didn't help. Still when i'm doing 12 o'clock engine turns off... Last time when did coaster i was landing with blocked rear wheel, it wasn't fun :/ I know that I have to do something wih carburators, but I don't know what and how..... I ride Honda Cb600 Hornet
Old Jul 15, 2005 | 06:55 AM
How can you make check valve ? And what is that exactly ? Sounds nice, but when I don't know what or how, I can't try it
Can anyone explain me this ?
Old Jul 15, 2005 | 05:01 PM
E-DUB OM's Avatar
AGGRESSION!
I heard the trick from one of the guys from BRESTUNT. I cant remeber who but ill try and find out for you
E
Old Jul 15, 2005 | 06:15 PM
CLUNKER's Avatar
check valves are used on fish tanks. and cars. if you go to a place that sells supplys for aquariums and such theyll have them there.
