motor mount problem....
Old Mar 4, 2005 | 11:39 PM
kataklysm666 is an unknown quantity at this point
i have a 02 gixxer 750...it was crashed "bad" on the right side..now i can't get the motor mount bolt all the way out on the left side once it get's about half way out it just seems to stop...is there a chance that the motor twisted and thats why it won't come all the way out should i try to jack up the motor to releave some of the pressure on the one side
Old Mar 5, 2005 | 12:08 AM
catach42's Avatar
catach42 is an unknown quantity at this point
Re: motor mount problem....
could have twisted the frame
Old Mar 5, 2005 | 01:36 AM
MIKE_SR's Avatar
MIKE_SR is an unknown quantity at this point
if it's stuck just.....just wrench harder it will come out. probably with the threads attached
Old Mar 5, 2005 | 10:01 AM
[QUOTE=DeltonaStunna]if it's stuck just.....just wrench harder it will come out. probably with the threads attached[/QUOTE
no ****.............but there is a frame slider on that side put on with a alen head bolt...so how hard can you wrench a alenwrench???????i'm thinkin heat it up...
Old Mar 5, 2005 | 11:30 AM
MIKE_SR's Avatar
go to a hardware store and buy a 3/8 drive allen key to fit the bolt...then use a ratchet.
Old Mar 5, 2005 | 11:34 AM
X DIZZLE X's Avatar
DIZZLESTUNTZ.COM
X DIZZLE X is an unknown quantity at this point
or just try and lossen up the whole engine
Old Mar 5, 2005 | 12:14 PM
new problem..............the fu(kin bolt broke
SlitZ
May 6, 2013 06:24 PM
OneNaked636
Jan 26, 2013 08:57 PM
Swavey
Nov 20, 2012 10:36 PM
dropNdestroy
Oct 17, 2012 04:45 PM
E-DUB OM
Dec 2, 2002 07:41 PM
