HELP!!! zx6r db conversion
Old Sep 16, 2011 | 03:35 PM
u531355's Avatar
u531355 is a decent person
ok so i have a 98 zx6r. its a streetfighter style instead of a stun but this would be easily answered here than newhere else probably.
im doin a dirt bar conversion and it currently has a 05/06 suspension front and rear including wheels.
so far the parts i have are 03/04 top triple, pro taper crf risers, fly racing bars, and z1000 brake lines.
my question is, will i have to order oversize throttle and clutch cables and how much longer will they have to be. im wanting a near factory look to how the cables fit and not coming from out from under the tank and be all over the place
Old Sep 17, 2011 | 01:13 PM
DrakStunt's Avatar
DrakStunt is a decent person
Re: HELP!!! zx6r db conversion
Depending on how much rise, and what bars your using they should still fit. Although it may require rerouting them through the bike. If you need new lines, you can order them from Motion Pro. Just tell them you want +4" etc... Not too expensive either.
Old Sep 19, 2011 | 09:07 PM
u531355's Avatar
im runnin a set of fly racing cr high bends.
i just wanna make sure i have everything before i tear it down AGAIN lol
Old Sep 19, 2011 | 11:25 PM
DrakStunt's Avatar
More than likely stock will work, but they may get real tight when turning bars all the way to one side or the other.
Old Oct 8, 2011 | 09:39 PM
u531355's Avatar
thanks for the help man. went and mocked everything up and looks like only thing need to replace is the brake line and i have one sitting here.
gotta have some light machine work done to the triple and ill be back on the road
swtorcredits
Apr 29, 2021 06:15 AM
sileralt
Sep 23, 2014 02:41 PM
7EVENTY7
Jul 29, 2014 01:38 PM
stoneystunts
Stunting Help and Advice
Feb 20, 2014 02:33 PM
cbrsexhundred
Sep 4, 2013 10:36 PM
