what gear to wheelie
Old Mar 25, 2010 | 06:53 PM
VinniB86's Avatar
VinniB86 is a decent person
Re: what gear to wheelie
No I'm slammin the Sub frame and draggin for a few feet and it just lays over or flips back. I no longer have a tail light or even fender eliminator anymore because of it. I've already replaced every single piece of plastic on this bike and it's not even a year old. I just can't figure out the balance point and where I should keep the RPMs at to keep it from draggin ***.
Old Mar 25, 2010 | 08:22 PM
haynmogli's Avatar
haynmogli is a decent person
Originally Posted by nickalltogether
50 tooth on an r6 is 2 up, on a 636 it's 10 up... a little different. To the OP: Take off your skirt and clutch it up in 1st *****.
yeah thought it was different ratios...but same principle for he most part!! i can clutch it up in 1st...the OP just has to get over the OH **** feeling
Old Mar 25, 2010 | 08:53 PM
ruthless rah's Avatar
90-day squid probation
ruthless rah is a name known to allruthless rah is a name known to allruthless rah is a name known to allruthless rah is a name known to allruthless rah is a name known to allruthless rah is a name known to all
im 60t rear and stock front...i use 2 be scared to clutch up in 1st but when i realized i wasnt gettin anywhere in 2nd gear then i went to 1st...all you have to do is get use to it...it took me a whole day to get use to that big *** sprocket and im higher up in the gears then you are...so if you gon be scared to clutch up in 1st then you mind as well hang it up like jordan
Old Mar 25, 2010 | 10:27 PM
VinniB86's Avatar
What I meant is I get the bike completely vertical and the *** slams the ground and drags. I no longer have any plastic on the back of my bike.
Old Mar 25, 2010 | 10:30 PM
i would say keep your rpms at wherever you wacked the clutch at...play around with your rear brake
Old Mar 25, 2010 | 11:57 PM
xxberlinettaxx's Avatar
xxberlinettaxx is an unknown quantity at this point
[quote=T/C;4293676
On a second note... Why would you want to touch your dick to another guys face? That really insulting you more then him [/quote]
yea true but if i close my eyes i can just imagine its a hott as chick like jessica simpson use to be. haha j/k
so anyways today i spent all day with this slow **** and finally getting it a lil better.. 1st is def better for slow stuff. i just raised my idle to 3k popped the clutch about a trillion times and whollla.
Old Mar 25, 2010 | 11:59 PM
Tone The Natural's Avatar
Zippy Tie Rider
Alright I'm new at clutchin a bike up. I usually just throttle it up. I have an 09 R1 and I've tried searchin it and I've watched tons of videos but these guys are tiny compared to me. Everytime I try to do what they suggest I 12 O'clock and go down. I need some input on what evryone else has done so I can try what y'all have been doin. I had a GSX-R 750 and I clutched it up in first or second. This new R1 is way different than the 750 though. Anyone got any ideas?
If you 12 o clock a bike and don't hit the brake, it's not gonna come back down. It'll come down after you're on the ground.
Old Mar 26, 2010 | 12:37 AM
45stunnaz's Avatar
45stunnaz is a decent person
Lol I love this thread I'm glad I'm not scrapin and slamming anymore.
Old Mar 26, 2010 | 12:46 AM
haynmogli's Avatar
what im interested to know is im dumping the clutch around 10k to get the front up is that not right? -1/+2 r6 it comes up about 3-4 feet sitting down. im going slow like almost stopped.
anyone??
Old Mar 26, 2010 | 01:20 AM
StrictlyStunt's Avatar
anyone??
you wanna slip the clutch, not necessarily dump the clutch.
Easiest way is to come to a complete stop... let off the brake, roll the throttle and slip the clutch all in one motion...
Old Mar 26, 2010 | 01:38 AM
haynmogli's Avatar
so going slow and then reving to 10k and dropping the clutch isn't good?...everyone says thats a loop waiting to happen but it never came close to looping for me
Old Mar 26, 2010 | 01:50 AM
if your doing it exactly how your saying it then yeah, prolly gonna loop it.
Chances are your body positioning isnt right and the tire is spinning or something, one day it's gonna hook and lights out
Are you bouncing it up at all, or moving your body at all when you clutch it up? Shouldnt need 10K RPM's
Old Mar 26, 2010 | 02:11 AM
  #33
CircaStunts's Avatar
CircaStunts is a decent person
+1- I hope it doesnt hook dude cause thats a slam waiting to happen
On my 08 Im 5up in the rear and -1 up front. Normally with the idle at stock used to come to a stop, clutch it, and kinda bounce it up. Then i would catch it with the rear brake and slow it down. It tooook alot of practice to slow them down. Now i run Idle at 3300-3600rpm and let it rip.
Old Mar 26, 2010 | 04:24 AM
  #34
haynmogli's Avatar
yeah thats what every one said...but i slowly worked my way up and it only started coming up around 8k...ill try what you said instead and bounce...i wasnt bouncing before...im pretty sure i have my rear suspension as stiff s can go and tire is at 30psi
Old Mar 26, 2010 | 04:44 AM
  #35
yeah try it. My 05 isnt that bad. Its stock gearing and I can slip the clutch and find BP quick. Just make sure you rock your gear and some huevos
Old Mar 26, 2010 | 05:10 AM
  #36
haynmogli's Avatar
haha yeah gear all the time...and the huevos came when i went that high in rpms...i knew it wasn't right but its the only thing that worked
Old Mar 26, 2010 | 05:13 AM
  #37
Shiiit i remember when riding the wheelie out to the rev limiter was cool. That was in the 75mph wheelie days
Old Mar 26, 2010 | 08:54 AM
  #38
T/C's Avatar
T/C
Squid...
T/C has a spectacular aura aboutT/C has a spectacular aura about
Practice man... Work on covering your brake and getting used to the throttle is all i can say Seat time really is the cure
So what you just told me is... You think its okay for a guy to do **** with your dick as long as you are pretending he is a guy in your eyes?
anyone??
Practice
Old Mar 26, 2010 | 01:16 PM
  #39
^^^ only under certain circumstances lol
cbrdoubler
Mar 13, 2023 04:19 PM
Stunt Medic
May 23, 2013 10:43 AM
Napkin Legend
Mar 9, 2013 12:03 AM
Napkin Legend
Feb 27, 2013 09:56 AM
D-Mann
D-Mann
Dec 8, 2004 08:13 PM
