db bars cbr600rr
db bars cbr600rr
i have a 03 cbr600rr im puttin protapers on it the throttle cables reach but thats it is there a way to make the clucth cable fit and the brake line or do i have to get new brake line and clutch cable?
Re: db bars cbr600rr
you CAN make it work, but it's ghetto and a tight fit..
the brake line will pretty much always be tight, but a couple of my friends got away with their stocker......
the clutch cable my friend had to reroute it and cut a hole in his plastic for it to go through, kinda stupid.. I'd just get a new cable
f4i cables are longer then 600rr's, but I'm not sure how much longer..
How did you mount the db bar brackets? Did you just drill the stick triple and mounted it that way? I only ask because I have bought em some clip one that don’t fit due the the bolts in the front of the stock triple. So I would like to run db bars but not tryna spend more money on stuff that doesn’t work lol.
