F4i Dual Fan Mod
Old Oct 6, 2009 | 04:48 PM
B0arder606's Avatar
B0arder606 is an unknown quantity at this point
F4i Dual Fan Mod
So would it be ok to hook the second fan up to the current fans power? My dad says itll blow a fuse if both are on at the same time (im gonna leave the first fan wired to the thermosensor and the second one to a switch and no sensor) He said to run a fuse off the ingnition switch then hook it to the switch and so on.
So what should i wire it to the current fan power or the ignition switch
Old Oct 6, 2009 | 06:58 PM
MoHawk's Avatar
Post Whore Nazi
Re: F4i Dual Fan Mod
Ignition switch. But on a switch. Not hard wired. That way you can turn it on or off. Then again, if you hard wire it to a switch, you can cut it on even if the bike is off.... Like sitting in NAsty traffic or with eating a sandwich at the lot
Old Oct 6, 2009 | 11:25 PM
B0arder606's Avatar
Yea i planned on running it through a switch for the dude, just didnt know where to hook the power to. SHould i run an inline fuse through the wire?
Were currently setting up this F4i for my bud and didnt know what to wire it to.
Thanks MoHawk
Old Oct 6, 2009 | 11:26 PM
MoHawk's Avatar
Post Whore Nazi
Anytime bud. An inline fuse is a good idea as long as it is easily accesible.
Old Oct 10, 2009 | 03:13 PM
MiNi GuineA's Avatar
www.STUNTRIDE.com
MiNi GuineA is a decent person
Thanks MoHawk
How did you mount the 2nd fan? I used the plastic quick connect ties for rad fans from the auto parts stores. They break and will funk up your core. I am going to find a **** rad and have the taba welded on mine.
Old Oct 10, 2009 | 04:21 PM
B0arder606's Avatar
We still havent mounted it but were gonna just fab up some brakcets ill take pics when we do
DeadlyInstincts
Jun 23, 2013 06:23 PM
DGLong
Feb 20, 2013 11:10 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
OneNaked636
Jan 12, 2013 12:31 PM
crew72
Dec 20, 2012 01:32 PM
