636 fan ?
Old Sep 25, 2009 | 09:03 PM
jamstoyz's Avatar
jamstoyz is a decent person
636 fan ?
i took my front nose off, moved my speedo, turn signals off, trimmed the front side fairings and now when i run my bike until it gets hot, the fan runs for a while when i shut the bike off. probably like a minute. is this normal? or does it have something to do with the **** i disconnected?
Old Sep 27, 2009 | 11:10 AM
B.A.M.F.
MattyB03 is a decent person
Re: 636 fan ?
Sounds like your bike is getting hot so your fans kicking on.. I took out my temp sensor and cut my fan line and ran it into a toggle switch and placed the switch inside my left side plastic.. Once my bike warms up, I turn the fan on and run it constant and flip it off when I'm done stunting..
Old Sep 27, 2009 | 03:38 PM
jamstoyz's Avatar
Re: 636 fan ?
yeah but the fan will still run with the ignition off?
Old Sep 27, 2009 | 04:52 PM
Re: 636 fan ?
dont eliminate the temperature switch just put a toggle switch between the two wires that go to the temp switch that way if you ever forget to turn on the fan switch the fan will still come on at the regular temperature ..
and yes it is normal for your fan to stay on even after you turn the key off if the bike is hot enough for the fan to be on ..
Old Sep 27, 2009 | 06:55 PM
jamstoyz's Avatar
Re: 636 fan ?
sweet thanks old man roger. the switch bypass is a great idea too. ill have to do this.
knowlzy0791
Jul 26, 2013 11:56 AM
eben48
Jul 17, 2013 10:38 AM
crf4i50
May 1, 2013 02:06 AM
loco leon
Jan 5, 2013 03:14 PM
