need help crf 150f
Old Aug 30, 2009 | 11:07 AM
D-WRECK's Avatar
D-WRECK is a decent person
need help crf 150f
Ok most of you know I stunt the little 150f, I know I can do more than what I'm doing now. Now my question is,
What rear wheel with full hydrolic brake set up could I put on the 150f?
The drum sucks ***** for the hand brake. It barely works but I can use it cuz I'm use to it. So what should I be looking for?
Old Aug 30, 2009 | 12:34 PM
Kevin ETP's Avatar
M.A.S.S. MAYHEM 4 OUT NOW
Kevin ETP is a jewel in the roughKevin ETP is a jewel in the roughKevin ETP is a jewel in the rough
Re: need help crf 150f
an f4i or a 636 thats what you should be looking for haha
Old Aug 30, 2009 | 12:36 PM
chinof4i's Avatar
FAT MAN STUNTING
chinof4i has a spectacular aura aboutchinof4i has a spectacular aura about
Hahaha^^^^^^^^^^^^^
Old Aug 30, 2009 | 12:57 PM
D-WRECK's Avatar
Stop itttt
Just need a quick fix. Ill have something bigger when tax comes around. Till then help a guy out. I need a hydrolic hand brake dammit.
Old Aug 30, 2009 | 01:00 PM
ANTI-SOCIAL's Avatar
O.T.L.
ANTI-SOCIAL is a decent person
i have a 150f and my handbrake works just as good as the footbrake . Try sanding the pads & hub .
Old Aug 30, 2009 | 01:20 PM
D-WRECK's Avatar
Could you put up pics of your set up?
Old Aug 30, 2009 | 04:21 PM
*Tanus*'s Avatar
AZ's Finest!
the lever that you use can make a big difference in HB power.
is there cyclegear shops near you? I can tell you the best lever Ive found if there is
Old Aug 30, 2009 | 04:24 PM
Towlieee's Avatar
sand the pads and inside of the rim with 80-120 grit sand paper, hose out wiht brake cleaner, and relube the brake pivot points
It's a 150f, it has GOBS of engine brake. Drum brake is sufficient for a little bike like this.
Hell you shouldn't even need a hand brake for anything that's not off throttle hand.. But I can understand wanting one just incase
Could also extend your rear brake arm where your hand brake attaches
Old Aug 30, 2009 | 05:58 PM
O.T.L.
+1 i cover the handbrake when i'm doing seat standers thats the only time i use it .
Old Aug 30, 2009 | 06:06 PM
O.T.L.
Here ya go , for the handbrake lever i just used the stock clutch lever & cut my asv lever (the ez pull would have been a better choice for the clutch lever)
Old Aug 30, 2009 | 07:59 PM
D-WRECK's Avatar
Where did you get the wheels? I can't find **** around here.
Old Aug 30, 2009 | 08:36 PM
O.T.L.
http://www.procycle.us/bikepages/crf150-crf230.html heres the link & i used the stock 150hubs .
Old Sep 1, 2009 | 05:51 PM
D-WRECK's Avatar
ok how did you get a rear peg on there???? how does it ride using them???
Old Sep 1, 2009 | 09:15 PM
O.T.L.
First we had to re-route the exhaust & fabbed up a bracket in the subframe w/ some tabs .
Old Sep 1, 2009 | 09:19 PM
ncgsxrboi's Avatar
ncgsxrboi is a decent person
you have any issues with oil starvation from long wheelies?
Old Sep 1, 2009 | 10:20 PM
D-WRECK's Avatar
Yeah I need to have some one fix up the frame. The sub frame (them two danky tubes) is twisted from the bar.
Old Sep 1, 2009 | 10:25 PM
D-WRECK's Avatar
No I haven't. Or haven't noticed it
Old Sep 1, 2009 | 10:35 PM
Kevin ETP's Avatar
no he said long wheelies you have nothing to worry about haha
Old Sep 2, 2009 | 12:45 PM
D-WRECK's Avatar
I challenge you ******. Ill go futher than you on the db. Braappp
Old Sep 2, 2009 | 01:06 PM
Towlieee's Avatar
If you got your bar mounted right to the end tubes, of COURSE it's gonna twist
Gotta run mounts going all the way down the subframe to the main frame, mounting in multiple locations kind of like a crf50 12 bar
