sick innovations cage on 08cbr600rr
Old Jul 22, 2009 | 07:16 PM
Arslinger's Avatar
Arslinger is a decent person
Sick innovations cage just came in. Went to install it and it seems that some of the bolts are too big and will not go into the tubeing of the cage to meet the threads. id call sick innovations but its after hours. it came with 2 bolts with nuts, a smaller bolt, and a long *** bolt that i take goes through the bottom. And I also take it, that 2 of the original bolts that go through were you have to cut through go back in, there too big tho. any help would be great.
Old Jul 22, 2009 | 07:22 PM
ct954's Avatar
ct954 is an unknown quantity at this point
Re: sick innovations cage on 08cbr600rr
drill it out bigger. The powdercoat could of built up.
Old Jul 22, 2009 | 07:39 PM
Arslinger's Avatar
i figured it out but the longer bolt goes through the middle of the frame, just over the rear seats. it wont fit should i take a little dremel and make it bigger?
Old Jul 23, 2009 | 01:46 PM
stunt fighter's Avatar
weed.
stunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond reputestunt fighter has a reputation beyond repute
are you ******* serious? if theyre that careless then i might just go with a different cage cause i was really considering SI for my cage. it wouldnt hurt to email them too, they replied to my emails in less then 5 minutes after i sent them a email.
you can contact them at sickinnovations@insightbb.com
keep us updated!
Old Aug 3, 2009 | 02:05 PM
Arslinger's Avatar
well i dremmeled a little bit and just hammered the bitch through. All is good now but i wouldn't recommend that **** to anybody on an newer cbr unless they feel like doing work.
Old Aug 3, 2009 | 06:34 PM
weed.
take some pictures of it cause i want to see.
my cage SI package is coming in two days from now and i want to see
exactly what the issue looks like.
Old Aug 3, 2009 | 06:45 PM
Dick Loogie Stunts's Avatar
www.myspace.com/impaktech
shoulda went with impaktechthat **** would never happen
Old Aug 3, 2009 | 06:48 PM
weed.
hey man F U ok?
lol
Old Aug 3, 2009 | 06:59 PM
bwesky's Avatar
bwesky is a decent person
yeah i just got a cage for my 05 636 same **** happenend to me, i think they layered the pc on too thick in that area
not that big of a deal though, i just used a different rod thats a little smaller, put some wachers on both sides and tightenend those ******* down. cage is fantastic BTW, quit ur bitching
Old Aug 3, 2009 | 07:36 PM
weed.
not that big of a deal though, i just used a different rod thats a little smaller, put some wachers on both sides and tightenend those ******* down. Cage is fantastic btw, quit ur bitching
Old Aug 4, 2009 | 10:11 AM
Arslinger's Avatar
yea that **** blew my mind.... ill have pics up today sometime
Old Aug 4, 2009 | 02:45 PM
weed.
well i called SI yesterday and they said its scheduled to come in on wed, but i looked it up on ups.com and tracked it down there and it says its been updated and its scheduled to come by today instead of tomorow. hurry up
Old Aug 4, 2009 | 02:49 PM
weed.
hahaha after i posted that i heard a doorbell
ran down stairs, last 6 stairs i did a karate kick and said yut ugghh
it was UPS, so im about to go to the garage right now and get to work
arslinger hurry up with the pictures you ****
Old Aug 4, 2009 | 03:07 PM
frayz's Avatar
J Blox
I got a brand new one from them a month or so ago. No problems..
Old Aug 4, 2009 | 05:55 PM
BandAidSquid's Avatar
BandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to beholdBandAidSquid is a splendid one to behold
keep us updated!
That cage is gangstalicious!!!!! Sick innovations makes cages not bolts..... My cage has hit many times on the left side and it's still running strong! Don't use the plastic sliders though buy the aluminum they're worth it
Old Aug 4, 2009 | 07:55 PM
weed.
alright so i just got done putting throwing on my round bar, it has 4 holes for bolts to go in. 1 on the left, another on the right, and 2 in the middle.
did you guys use 4 bolts? cause im just using my stock bolts
i bolted one on the left
and one in the middle right.
total of 3 stock bolts, you guys think i should have bolted the middle left too?
just curious to see how you guys did it.
you guys think thats ok?
Old Aug 4, 2009 | 09:35 PM
weed.
how in the **** do you take off that 11/16 stock bolt where the sick cage needs to be bolted on?! i even tried using my own weight to jump on the wrench but it wont budge, not even a tiny bit.
Old Aug 4, 2009 | 09:46 PM
nickalltogether's Avatar
Yut-ugh.
SI doesn't powdercoat the cages, they outsource that. And I probably wouldn't use the stock bolts if I could avoid it, just because they might not be tough enough to take any kind of impact.
Old Aug 4, 2009 | 09:55 PM
weed.
**** man that bolt is hard to take off
Old Aug 5, 2009 | 09:53 AM
that rb is a mothabitch on our bike I think I had to put the center bolt in first though, it would make since because that's going to be the first section of your subframe that breaks off once you scrap it lol
be careful with that bolt don't stand on it!!! What kind of wrench are you using get the biggest one you have and try puttin a pipe on the end be extremely careful ez outs are cool an all but you dot want to use them haha
