sick innovations cage on 08cbr600rr
Re: sick innovations cage on 08cbr600rr
it wont use the stock bolts there too big dude. as for that long one your going to have to beat that bitch in with a mallet or a hammer. nothing unbolts there, you just run that rod through.
that rb is a mothabitch on our bike I think I had to put the center bolt in first though, it would make since because that's going to be the first section of your subframe that breaks off once you scrap it lol
be careful with that bolt don't stand on it!!! What kind of wrench are you using get the biggest one you have and try puttin a pipe on the end be extremely careful ez outs are cool an all but you dot want to use them haha
10mm on the left and right and a long 12mm in the center.
you didnt answer my question about using stock bolts or not
what do you mean my subframe will break off as soon as i use the RB
and for the sick cage.....
rod goes through the center kinda above the foot pegs,
tiniest screw goes in to connect the cage through the headers
and the last 2 goes on where i cant take that ******* stock bolt off
sounds about right?
I used the center stock bolt and got new side bolts. I was saying the center of your subframe at the tip will crack after a few scraps.... Trade that bike in before you trash it
dude the stock bolts you take out are suppose to go back in. and plus they are way to big and wont go into the tubing of the si cage. the only problem i had was that damn long *** bolt that goes through by the rearseats jus hammer that bitch through and your all go. SI makes a sick cage, mine has taken some abuse and is still mint
i had a gixxer before this, wasnt caged or bar'd out though, learned on that bike. never laid it down and it was a street fighter. looking back at that now i realize how much of a dubass i had been. if i would have laid it down the engine would probably break off of the frame lol.
but this cbr is the first bike i actually invested protection on
(not the single tiny one, not the long rod) but the two same size bolts
are you seriously having this much trouble with this!?!? Lol just playing the stock motor mounts will not fit through the cage take the two four to five inch long Allen head bolts and put them where your motor mounts were when I did it I used washers and locking washers... Put a washer and a nut on the back of each of them. Does that help?
are you seriously having this much trouble with this!?!? Lol just playing the stick motor mounts will not fit through the cage take the two four to five inch long Allen head bolts and put them where your motor mounts were when I did it I used washers and locking washers... Put a washer and a nut on the back of each of them. Does that help?
yeah thats what i thought
that arslinger dude as you can see a couple posts up from here he said
the stock bolts i take off have to go back on
but anyhoot
how did u take off those stock motor mount bolts
Mine came out fairly easy I think... What size drive wrench are you using?
I can't really remember all the details but I'd use atleast a ratchet with a half inch drive and find a pipe to put on the end of it and slowly loosen it you do not want to snap that **** off, it may just be a little tight from lok tight or whatever
finally got those *17mm stock bolts off that the ******* honda manufacturer lock tight'd on
about to start the hammering the rod starting on the left side
you guys did hammer on the left side right?
you really need punctuation marks bro lol
bolt head is on the left or right side.
and does it really matter?
stunt fighter you blow my ******* mind bro lol. not one stock bolt go back in. and you only take the two out lol. the only problem is that long *** rod. which u can hammer the ****** through or buy a smaller one. thats all dude. Reason im stunting my **** out is because i hit a deer and got 4 grand for the busted ****. which was all cosmetic and could have been fixed with 1g. that equals a DEAL. ill post pics up of my ****
