f4i problem
Old May 2, 2009 | 06:11 PM
brettcr is a decent person
f4i problem
i did the tip over sensor and have the idle set at 3500 but when i ride balance point in 1st gear the bike shuts off. what would cause it, going to slow maybe?
Old May 2, 2009 | 06:16 PM
dmcfreestylematt's Avatar
RedruM
dmcfreestylematt is a jewel in the roughdmcfreestylematt is a jewel in the roughdmcfreestylematt is a jewel in the rough
Re: f4i problem
loose ground maybe ?
Old May 2, 2009 | 06:19 PM
Towlieee's Avatar
Re: f4i problem
Bad connection somewhere
it could be anything, get to searching.. Get your bike running on hte kick stand and start jiggling wires, find out what you jiggle to kill it, then inspect..
One little wire losing connection and the bike wont run
Re: f4i problem
loose ground on what the tip over sensor?
Old May 2, 2009 | 06:24 PM
RedruM
Re: f4i problem
like towlieee said anywere
start with ur main ground wire
Old May 2, 2009 | 06:32 PM
chpsk8er630's Avatar
chpsk8er630 is an unknown quantity at this point
Re: f4i problem
Never did the tip over sensor and never had the bike shutoff in a wheelie only when the bike falls on its side
Old May 2, 2009 | 06:34 PM
DCP-TED's Avatar
DCP-TED is an unknown quantity at this point
Re: f4i problem
check inside the throttle housing. Maybe a wire is lose on the kill switch.
Old May 2, 2009 | 06:44 PM
Re: f4i problem
yea but the bike has never shut off when just riding normally its only happenin right when i clutch it up to balance point i cant be goin more than 5mph since im clutchin it up from a stand still
Beastin4shot
May 9, 2013 04:49 PM
kchad917
May 2, 2013 07:20 AM
Demon87
Feb 3, 2013 08:58 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
Jeffknight27
Dec 3, 2012 10:55 PM
