F4i oil pickup .
Re: F4i oil pickup .
myself, and 2 of my friends have been stunting the f4i for years without an oil pickup mod. if you really want to do it, then go ahead, it cant hurt! but you really do not need too!
Ok, thanks for answer
I have 36k on my engine. I bought it with 15k and instantly went to stuntin. I do regular maintenence. And I do bar tricks. Just not for way long periods. And I don't do burnouts on the bar. But I do a ton of revlimit caosters all day. No oil pickup needed. But if I had the money to just throw out for one, I definitely would. It can't hurt. And I ride a few mile wheelies with no problems ever. My light hasn't ever come on besides draggin on the bar for a bit. I run my oil right to the top of the sightglass. So about a half quart or so over top line.
i took my sump of and turned pulled the oil pick up out and turned it 180degrees!
when doin a wheelie it would put the pickup hole about 1-2inches lower meanin it is in more oil!
this mod cost me nothing so it is well worth the effort! i know a few guys over here in australia that swear by it!
Was told about this mod, turning the oil pickup 180 degrees, but was also told you need to fabricate some type of tabbed washer to keep it in place?
Or will it stay there on its own when turned around?
Cheers.
Cheers.
+1
You have convinced me that modified oil pickup not needed. i took my sump of and turned pulled the oil pick up out and turned it 180degrees!
It is difficult whether it be done?
dude it is easy as pull ya header pipes off drain ya sump!
pull the sump off pull ya pick up out turn 180 put it back in!
that easy!!!!
it stays in there and if it did come out the sump will hold it in there it works great
that easy!!!!
dude they r lies all the oil pick ups u can buy r a waste of time. just spin it 180 cost u $$$$0 so its worth it.
I have some Stuntex f4i pickups in stock if anybody wants one. $79 shipped
BlackMarketBike
Jul 9, 2024 03:25 PM
