rear braking question
Old Feb 12, 2009 | 06:52 AM
tattoofreak's Avatar
tattoofreak is a decent person
About how long did it take everyone to learn to use there back brake while there wheeling. I know everyone is different I just wanna see the differences so I could get a clue.
Old Feb 14, 2009 | 12:51 AM
southcoastrider's Avatar
southcoastrider is a decent person
Re: rear braking question
dont worry about how long it tool anyone just work at your own pace!
i found it easy to go in a big open area and turn my idle upto about 4grand pop the wheel up and back off the throttle!
keep goin higher and higher with each try till when u back off the throttle the wheel keeps goin up then lightly tap the brake! worked for me! takes time mate!
Old Feb 17, 2009 | 05:51 PM
trid's Avatar
trid is a decent person
the way I learned to wheelie was to put the bike in 3rd or 4th gear and stand on both back pegs then clutch it upthat way it doesn't come up so fast that's just wat worked for me tho
Old Feb 17, 2009 | 05:58 PM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
Took a couple of days to get used to it i guess. The more difficult part is having good throttle control......that is key
Old Feb 17, 2009 | 06:03 PM
Dat_Boi's Avatar
Dat_Boi is a decent person
And if the bike comes back to far then what???? That just sounds scary without a hb.
Old Feb 17, 2009 | 07:00 PM
hey thanks for the info i will try it when it gets a little warmer here. so i could pretty much get rolling about 4-5 mph then pop the clutch does that sound good enough. i also have a 53t rear if that matters. any comments appreciated thanks.
Old Feb 17, 2009 | 10:25 PM
Dat_Boi's Avatar
Your asking the same ?'s a 1000 ppl have asked before. Try using the search button (if it works) All ur ?'s will be answered......
Old Feb 17, 2009 | 10:39 PM
stick1300's Avatar
Squid Supreme
stick1300 will become famous soon enough
I learned on a fiddy. Waaaaaay easier.
Old Feb 17, 2009 | 11:54 PM
zxcraig's Avatar
zxcraig is a decent person
my brake control sucked when i did fast wheelies,,, as soon as i started hitting the lots it took about a week to have it down to where you just do it without thinking about it.
Old Feb 18, 2009 | 09:43 AM
trid's Avatar
+1 lots help a ton
Old Feb 18, 2009 | 09:46 AM
trid's Avatar
It's not that bad it doesn't come up that fast and if u get back too far you have leverage over the bike to push it down
Old Feb 18, 2009 | 10:41 AM
Ok bro thanks ill just ask once thanks for the help. Later
stuntin'_cbr
Nov 20, 2024 11:08 PM
blayl
Dec 3, 2012 02:17 PM
blayl
Nov 29, 2012 03:23 PM
unstopablee1
Oct 12, 2012 07:12 PM
Jay Carnes
Oct 17, 2002 03:25 PM
