1st Gear Wheelies?
Old Oct 28, 2002 | 02:52 AM
Lance__'s Avatar
Lance__ is an unknown quantity at this point
Question 1st Gear Wheelies?
Ok i can do first gear wheelies... but i always seem to pick up alotta speed or at least use up alotta my tach.... How do i slow my first gears down like in the triple Xtreme videos???
Old Oct 28, 2002 | 09:25 AM
Soumy16's Avatar
Soumy16 is an unknown quantity at this point
gear your bike, go higher in the rear, Clutch it up. I dunno see if that might help
Old Oct 28, 2002 | 09:39 AM
You need to clutch it higher from the start on that bike.
Old Oct 28, 2002 | 07:57 PM
NICK HILL's Avatar
ScooterTrashST.com
NICK HILL is a decent person
get steel braided brake lines, bigger rear sprocket, and ride the slightly as you bring the bike up in a wheelie. im still learning too
Old Oct 30, 2002 | 07:59 AM
Pete_SOI's Avatar
Pete_SOI is an unknown quantity at this point
Old Oct 31, 2002 | 05:03 AM
Lance__'s Avatar
Steel braided lines???? i want help not some one to make fun of me..
Old Oct 31, 2002 | 03:06 PM
NICK HILL's Avatar
ScooterTrashST.com
with steel braded brakelines you wouldnt get as much brake fade. i wasnt trying to make fun of you. when you ride slow wheelies your pretty constant on the throttle, its the brake that smooths out the wheelie.
Old Oct 31, 2002 | 04:47 PM
SCoast AStar13's Avatar
I'm Getting Used to Posting
SCoast AStar13 is an unknown quantity at this point
your stock lines suffer expansion from the heat caused by riding on the brake constantly... this is fade...by changing over to a braided line as stated above,you won't feel any fade at all. Just dont be as quick to slam on the rear cause it'll lock up alot easier but thats more fun now Too:devil
Old Nov 1, 2002 | 10:18 AM
Rick929 PBR's Avatar
RickNasty.com
Rick929 PBR is an unknown quantity at this point
its not about gears
gears wont automatically make ur wheelies slow down, u pick up speed bcuz ur barely off the ground, its about heighth, throttle and brake control
practice settling a wheelie at 50mph and under....or....just get a 4 wheeler and 12 that, then 12 a small dirtbike and it'll channel str8 into ur streetbike
Rick929
C-Dub
Jun 12, 2013 11:44 AM
Stunt Medic
May 23, 2013 10:43 AM
tbleu1
May 1, 2013 05:40 PM
akiraruns
Oct 22, 2012 01:23 PM
D-Mann
D-Mann
Dec 8, 2004 08:13 PM
