spongy hb..help
Old May 18, 2008 | 03:08 PM
idragbodys10's Avatar
idragbodys10 is an unknown quantity at this point
spongy hb..help
just hooked up hb, dual caliper hohey..
pump brakes up and they work great, let sit for 2 sec. and there spongy and dont work!!...
using pump/vac to bleed..
any suggestions?
tryed a few things that i found in search, but nothing seems to work for me..
Old May 18, 2008 | 04:30 PM
chadnine's Avatar
chadnine is a decent person
Re: spongy hb..help
just had that problem with mine.....my line had a little kink in it. i was told there is no way to fix the line. put a new one on and it works perfect. locks the tire with one finger on the lowest setting
Old May 18, 2008 | 04:36 PM
Re: spongy hb..help
line is brand new, so hope that isnt the prob. guess it could be tho..
been messing with it for 2days, and still nothing....
Old May 18, 2008 | 04:38 PM
Re: spongy hb..help
when i bleed my brakes i just open the bleeder and put my finger on it and pum away , the finger on the bleeder lets air and fluid out but wont let air back in ...
if you don't want to make a mess then you can just put a hose on the bleeder and pump away just put the other end of the hose in a can or some thing but keep it higher then the caliper so the hose fills up with fluid so no air gets in..
and make sure the line from your resivoir isn't kinked also
Old May 18, 2008 | 07:07 PM
villa76's Avatar
Not guilty
Re: spongy hb..help
nice tip guy!
Old May 18, 2008 | 07:08 PM
Re: spongy hb..help
you peeking on me when im peeing....lol
Old May 27, 2008 | 01:22 PM
Re: spongy hb..help
got a radial master now, still nothing....
pump and really doesnt get pressure
chino17
Oct 2, 2012 07:41 AM
BVRider1
May 14, 2008 08:46 PM
youngStuntRyda
Jun 13, 2007 10:29 PM
cole
Oct 15, 2006 05:50 AM
FarleySF
Jul 12, 2006 03:02 PM
