Streetfighter Wires Everywhere?
Old Nov 5, 2007 | 06:14 PM
Stubbz's Avatar
Just wondering where you guys put all the wires and such when running a streetfighter headlight, and if theres anything in particular you have to do for airflow and so on to ride all the time with a streetfighter setup. i have seen guys with F4Is tuck the wires into one side of the airbox entry, but 03 636s are setup different. post pix if possible
Old Nov 5, 2007 | 06:43 PM
Stubbz's Avatar
Re: Streetfighter Wires Everywhere?
Bump... Anyone
Old Nov 5, 2007 | 06:46 PM
I can Get pics In awhile But there Just Crammed
Behind My Acerbris.. Nothing Special..
Old Nov 5, 2007 | 06:53 PM
N.Q.I_Dave's Avatar
The Ego
N.Q.I_Dave is an unknown quantity at this point
Cable tied together behind the acerbis. If you're staying streetfighter it helps if you cut out a lot of the excess wire.
Old Nov 5, 2007 | 08:38 PM
Stubbz's Avatar
well considering i just chopped my fairing off for the side plastics its deffinately staying a streetfighter, maybe i'll go through and chop some stuff out and see where i can hide the rest, some have said to put them under the gas tank in one side of the air induction tube so thats probly where they will go, just want a clean look thats all
Old Nov 6, 2007 | 12:44 AM
Joker's Avatar
I stuck all my wiring under my tank and I think Optimus Prime did the same thing on his 636.
Old Nov 18, 2007 | 04:15 AM
Boris-p's Avatar
Boris-p is an unknown quantity at this point
Yeah me to ... its a pain in the *** but it works and looks good allso..
Under the tank:YEAH
Old Nov 18, 2007 | 04:35 AM
LynchMob's Avatar
LynchMob is a decent person
u can chop up the wireharness if u want and keep only the **** u need. or just zip tie it all nice and shove it behind the mask or under the tank as said above.. also...where in ny are u from? another long island guy? lol
Old Nov 18, 2007 | 09:57 AM
Stubbz's Avatar
yeah i got mine all tucked away nice now. i dont see any sense in cutting the harness apart there isn't that much really. i'm from central new york bout 20 minutes east of syracuse
Old Nov 23, 2007 | 02:27 PM
blinkybill04's Avatar
blinkybill04 is a decent person
I'm just doin this to my F4i right now. i have everything i need to go FF, but i wanna paint everything pretty, and hopefully get some squidly mistakes outta the way before i just destroy everything... I wanna keep my gauges as well, that might be a bit of a trick!
Old Nov 23, 2007 | 05:34 PM
Stubbz's Avatar
nah it can be done fairly easy, harder if you have a gpr but easy without, just get big black zip ties and zip tie it to the upper triple
Old May 19, 2008 | 09:05 PM
kirny's Avatar
kirny is a decent person
this could be dumb question but 636's have the center air induction so does it still get enough air
Old May 19, 2008 | 09:26 PM
old duffer's Avatar
Registered Spammer
I just taped them all together and let them flap in the breeze
Old May 19, 2008 | 10:33 PM
REVLIMIT's Avatar
REVLIMIT is an unknown quantity at this point
I extended all of my wiring to under the tank....it took some time to cut and solder all the wires but it looks WAY better. On my bike actually you can only see about three wires and that's it everything else is hidden. So you don't see the wires by the frame, by the radiator, etc.
Old May 20, 2008 | 04:48 PM
timleg's Avatar
timleg is a decent person
I ran all my wires tucked under my frame/side my tank/airbox, if that makes sense...
I just ran the single headlight harness up to my lights and tucked those behind the lights, used a zip tie, to tie it to the hole the the old fairing stay used to be.
Old May 22, 2008 | 01:09 PM
TL MILLER's Avatar
TL MILLER is an unknown quantity at this point
If your keeping it s/f cut the wires down
Old May 22, 2008 | 01:55 PM
crashtest 750's Avatar
crashtest 750 has a spectacular aura aboutcrashtest 750 has a spectacular aura aboutcrashtest 750 has a spectacular aura about
I just tied my wireing across the top of my radiator. The 636 does get enough air in the airbox without having the induction. Just don't block it too badly.
Old Jun 4, 2008 | 06:35 PM
pixel 6's Avatar
pixel 6 is an unknown quantity at this point
I spent the better part of an evening drawing out a wiring diagram, labeling wires, and then snipping and soldering somewhere near 60 new connections. Used heat shrink tubing on all the new connections, and put all the wires in a loom.
The end result, is I have a single small loom running from my instrument cluster back to under the air box. Every thing else is zip tied up nicely in there. I also run all my clip-on gauges, so did the same thing on those... ie start/stop, blinker/headlight.
- Pixel -
Old Jun 13, 2008 | 11:02 AM
GSXR Carlos's Avatar
Professional Work Avoider
GSXR Carlos will become famous soon enoughGSXR Carlos will become famous soon enough
most of mine is tucked back under the tank, i had to take my starter motor off though to allow the fuse box to fit back under the frame
cc250r
Dec 8, 2013 12:36 PM
Candyman
Oct 7, 2013 06:46 PM
aznxstazy
Jul 15, 2013 08:09 PM
Lukas_Walker
May 27, 2013 05:51 PM
