more f4i problems
Old Oct 6, 2007 | 02:22 AM
needles_929's Avatar
needles_929 is an unknown quantity at this point
more f4i problems
i read through the whole sticky forum on tip over sensors but my problem hasn't been helped.
All I did was disconnect the whole wiring harness to the headlights where I already had the tip sensor disconnected. I jumped the wires at the main harness for the tip sensor and now the bike won't start. The fuel cut relay just clicks when you turn the key on. Even when I hooked the harness back up the way I had it before it just clicks?????
Anyone have the same issue or advice????
Old Oct 6, 2007 | 04:27 AM
DirtyToes's Avatar
DirtyToes is a decent person
Re: more f4i problems
hmmmm
check fuses
check relay
Old Oct 6, 2007 | 08:55 PM
F4EaSyE's Avatar
F4EaSyE is an unknown quantity at this point
cmon guys someone has to have had this problem before.. I am trying to get this damn thing running... needles has to hit the lots by himself until i we get this back up and running.. that means he gets to see no crashes.. :YEAH
Old Oct 6, 2007 | 08:57 PM
cjstunts's Avatar
cjstunts is an unknown quantity at this point
check the bank angle sensor, i think its the bottom one, and check the main fuse...
Old Oct 6, 2007 | 09:01 PM
Suicidl's Avatar
WWW.Sickinnovations.com
did you jump the right wies?
its the red and green one and leave the white one alone
Old Oct 6, 2007 | 09:08 PM
cjstunts's Avatar
he took the whole headlight harness off... so he had to jump it on the main harness, i forget what colors those wires are...
Old Oct 6, 2007 | 09:14 PM
Suicidl's Avatar
the same they are on opposite ends of the main harness the green is just a common ground
Old Oct 6, 2007 | 09:15 PM
according to the service manual the main harness wire colors for the bank sensor are the same color. the fucked up thing is that even when we plugged the front harness back in it still does the same thing. all fuses are good and the fuel cut relay is good. That is the relay that just keeps clicking when I turn the key on. It won't turn over or start or anything
Old Oct 6, 2007 | 09:18 PM
Suicidl's Avatar
there is a way to jump that relay and see if it will start
Old Oct 6, 2007 | 09:20 PM
again all I did is unplug the front harness that already had the tip sensor mod and jumped it at the main harness???
how
Old Oct 6, 2007 | 11:22 PM
cjstunts's Avatar
you have to bypass it, should be 4 wires, 1 signal in, 1 signal out 1 constant in, and 1 ground, just jump the constant in and the signal out, and it should start, manual should say which wire is which
Old Oct 8, 2007 | 01:19 PM
update:
both the fuel cut relay and engine stop relay check out good. I tried to bypass the fuel cut relay and it still did nothing. Fuel pump does not prime from turning key on but checks out good hooked to strait power. Also there is power to the harness at the fuel pump connection for a few seconds just like the service manual says.
still the fuel cut relay just clicks a bunch of times when key is turned on. When I take the jumper out for the bank angle sensor it stops clicking.
Old Oct 12, 2007 | 10:06 AM
Anyone reading this if you have a similiar issue buy a new battery first thing. The battery in the f4i that we were having problems with checked out fine even after bringing it to the shop and placing it on one of their high $ testers. They did say that the YTZ10S batt is a hunk of **** and they just go bad constantly.
New batt = good running bike
Old Oct 12, 2007 | 10:23 AM
binder929rr's Avatar
back in the saddle again
dang, you beat me to it. i was just going to say that it's the battery. anytime it clicks when trying to start it and the relays are good, you aren't getting the current to turn anything over.
glad you got it fixed.
Beastin4shot
May 9, 2013 04:49 PM
kchad917
May 2, 2013 07:20 AM
Demon87
Feb 3, 2013 08:58 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
Jeffknight27
Dec 3, 2012 10:55 PM
