Having problems with stoppies!
Old Oct 2, 2007 | 12:50 AM
trickshow's Avatar
trickshow is a decent person
I can do em' at 30 mph or less but any faster like 40 or 50 my tire ALWAYS skids on me? I grip the tank every time and put my weight over the handlebars (I only weigh 125) and I always pump the brake twice, once to compress my shocks and again to bring the back up, but I always feather the back up I don't wip it up in a second like the pros. do yet. I'm really starting to get annoyed of my front tire skidding. Has anyone else had this same problem I have when they first started rolling them? Is there a special way to do em' at higher speeds, or am i doing something wrong here? And YES my tire is warm and I have 30 psi when I do them. Any advice will help thanks
Old Oct 2, 2007 | 12:55 AM
Re: Having problems with stoppies!
try 25 psi and don't pump the brake just transfer your weight and brake at the same time ,and you kind of have to whip it up or the tire will slide
i mean you don't have to whip it up to balance point if your not ready for that but you have to whip it up some what to get it started
Old Oct 2, 2007 | 01:03 AM
trickshow's Avatar
Aight, gonna go out and practice them all day tomorrow. Hopefully I will be able to whip it up without skidding.
Old Oct 2, 2007 | 01:05 AM
do a bunch at you normal speed to warm up then just go a little faster
Old Oct 2, 2007 | 09:08 AM
samurai87's Avatar
samurai87 is a decent person
Im in for some advice as well!! I usually jus pinn out 1st gear and hit it, but I dont really play around with them much. I just need to get more comfy with the tire coming up, I never let it come that far off the ground haha my lil ***** endos like 8-10'' off the ground maybe!!!
Old Oct 2, 2007 | 09:23 AM
RUStunter's Avatar
RUStunter is a decent person
i had the same problem. let the Air out to 20 PSI. and the first couple of times dont go for distance... meaning, compress the forks slowly and same with the front brake.... then when you get the rear wheel up, and your front tire is warm, be more aggressive and hit the front brake faster and get the rear end up quicker.
Old Oct 2, 2007 | 09:34 AM
DSC's Avatar
DSC
also being a little(5'9 135lbs) guy i found that if you soften your suspension some it helps with the preload. but deff make small adjustments to your front suspension untill you get it how you like it. and then its just practice.
Old Oct 2, 2007 | 09:37 AM
+1
Use low pressure until you learn the technique
Old Oct 2, 2007 | 09:42 AM
samurai87's Avatar
hmmm, well i need a new front tire first, this one is cached!! plus i think your right, I'm prolly running 30something in mine right now! I will deff try this out prolly this weekend
Old Oct 2, 2007 | 10:16 AM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
I am shorter and weigh less and i like my suspension hard as a brick for endos
I mean, look at my avatar <---------------
Old Oct 2, 2007 | 10:19 AM
NINER's Avatar
Retired
I like compression all the way soft and rebound all the way hard. but i suck at stoppies so take that with a grain of salt.
Old Oct 2, 2007 | 10:33 AM
stiff is good for rolling them really far but it can make the tire wanna slide if you don't transfer you weight
Old Oct 2, 2007 | 11:03 AM
binder929rr's Avatar
back in the saddle again
why do people pump the brakes? it doesn't do jack. knock that crap off.
you have 1 of 2 problems. your tire isn't sticky enough or the surface is dirty not allowing grip.
i'm going to take a guess that you have a junk *** tire. just because it has tread doesn't mean the compound isn't destroyed and hard from being old. replace it with nice new tire.
Old Oct 2, 2007 | 11:13 AM
DSC's Avatar
DSC
i have my compression about half soft and rebound hard. i really throw my weight tho. but to each his own, its all about what is comfortable to you. i have completely stock f4i front end too, not that it matters
Old Oct 2, 2007 | 12:05 PM
cisco5311's Avatar
cisco5311 is an unknown quantity at this point
nice sticky race take offs work wonderfull
really soft compound tires hook up well
I've got a race take off slick on the front now, has never locked up on me, it chirps a little when pullen them up at 80mph but doesn't lock up
Old Oct 2, 2007 | 07:55 PM
YodaCon is an unknown quantity at this point
I keep my suspension soft, bend my lever out a bit, run a pilot front tire and tire pressure around 20psi
start off in first go as fast as you want let off the gas and hit the brake. you wont have to throw all your way forward and the suspension will be preloaded from accelerating and letting off, use the bikes momentum. keep trying to get it higher and higher etc... you will know when your on the right track. its all or nothing with endos.
thats how i learned
Old Oct 2, 2007 | 08:03 PM
villa76's Avatar
Not guilty
Old Oct 2, 2007 | 09:17 PM
trickshow's Avatar
alright i can roll them for about 30 feet now but my front tire has NO tred at all left. completey bald!! i just gotta learn how to wheelie now.
Old Oct 5, 2007 | 10:05 PM
louisvillerider's Avatar
Originally Posted by villa76
i never have a problem out of ract take off's either... think about it.. they are made to grip
Old Oct 5, 2007 | 10:22 PM
when i was learning how to do stoppies i could toast a tire in a few days...lol
once you stop doing power stoppies and start getting them up to balance point your tires and brakes will last a lot longer
