f4i light kill switch
Old Sep 18, 2007 | 10:15 PM
Sikgixxer750's Avatar
Sikgixxer750 is an unknown quantity at this point
Hey i'm looking to wire up a cut off switch to kill the headlight and taillight on my f4i. I went to the elecrical store and got a switch that will break the circuit. My question is where is the wire that connects both the headlight and taillight if one exists or where would be the best place to cut the wires and splice this switch in. Thanks
Old Sep 18, 2007 | 10:17 PM
Re: f4i light kill switch
My current headlight set up is the acerbis diamond spliced into the stock headlight wires.
Old Sep 19, 2007 | 12:26 AM
For the headlight, you just wire it onto the high beam, and dont use the low beam. That way your hi/low switch will act as an on/off switch.
For the tail light, cut into the ground wire and put a switch on it.
If you're good with electrical ****, you could use a relay, triggered by the hi beam switch.
Old Sep 19, 2007 | 01:18 PM
Thanks man
eben48
Jul 17, 2013 10:38 AM
speedjunkies
Jan 14, 2013 05:55 PM
Jeffknight27
Dec 3, 2012 10:55 PM
eamonhoffman
Oct 14, 2012 07:51 PM
jaxon23
Nov 27, 2002 03:06 AM
