Stompgrip worth the money?? + tank dent fix
Old Sep 10, 2007 | 12:56 PM
Sparks!'s Avatar
Sparks! is an unknown quantity at this point
I wrecked a pair or jeans in under a day with skate grip tape stuff, so I'm looking for other options.. is stompgrip any good for the tank? its really expensive in the UK, looking at £35 which is about $70 is it worth the ££$$$ ? or any equally good but cheaper options?
Also, I need some help sorting my tank, I don't know if I can get mine how I want it without having to replace the tank? its too shallow and I slip off wayy too easily.
I've put a pic of mine on... anyone got any advice how I can make this deeper/better without wrecking it? Should I start at the cap again and work it out and deeper... I'd be okay starting afresh, but not sure how to "save" this tank which was done over a year ago when I first started is it savable or will it just end up creasing and splitting?
Old Sep 11, 2007 | 03:33 AM
Street Warrior's Avatar
Re: Stompgrip worth the money?? + tank dent fix
Try to get some hydro-turf. Like they put on jetskis. You only need a little piece and you can probably get some scrap at a local jet ski shop or buy some off ebay like this http://cgi.ebay.com/ebaymotors/TIGER...spagenameZWDVW and do 3 or 4 bikes with it.
Or get a surfboard stomp pad like this
http://cgi.ebay.com/Poorboy-SkyhookT...ayphotohosting
you would never come off the back with that thing on there!
your dent looks fine to me you just need some traction.
Old Sep 11, 2007 | 03:41 AM
very small light wacks with a rubber hammer all around the rear part of the dent working all the way from one side to the other very slowly and making small changes in the dent should work just don't try to do it all at once be patient and just work it slowly ....
+1 on the surf stuff alot of people use that around here and it comes sticky so no spray glue needed just clean your tank good before you apply it make sure there is no gas or oil or wax on the tank
Old Sep 11, 2007 | 04:04 AM
Suicidl's Avatar
WWW.Sickinnovations.com
this is all you will ever need
http://www.techspec-usa.com/gensheet.html
Old Sep 11, 2007 | 04:23 AM
marcus_136's Avatar
marcus_136 is an unknown quantity at this point
I bought that **** and it was like no grip at all. I threw it away because it didnt have any good grip compared to standard griptape.
Old Sep 11, 2007 | 04:27 AM
Suicidl's Avatar
thats all i use
Old Sep 11, 2007 | 10:53 AM
marcus_136's Avatar
thats all i use
Might have to do with that your tank is better dented then mine, then you dont need as much grip to hold on... Hell I fell off doing spreader circles with griptape on the tank... http://www.youtube.com/watch?v=GfMo1bLWUHI
Old Sep 11, 2007 | 03:04 PM
*Tanus*'s Avatar
AZ's Finest!
try tapping the tank on the black line w/ a ball peen hammer. Hit it at a backwards angle as opposed to downward. Take LOTS of light taps.
I think stomp grip sucks ***, hit holds awsome,but looses its adhesive very fast,especialy if you do frogs.
I use jet ski foot grip, then I added grip tape coated w/ rubber bedlinner at the front to keep the jet ski stuff from coming loose there.
Old Sep 11, 2007 | 03:13 PM
Sparks!'s Avatar
Cheers for the advice, I'll try and get it a bit deeper.. I got some of that surf board grip stuff , I tried it before and didnt think much to it and it didnt stick to the tank well.. I might try it again, but it didnt seem to offer much grip really...
ill try it out and see how it goes
Old Sep 11, 2007 | 03:18 PM
Sparks!'s Avatar
Anyone use this stuff?
If so does it rip your trousers (pants) ? its a soft material and it is pretty damn grippy.. thinking this might be a cheaper alternative.
Old Sep 11, 2007 | 03:23 PM
*Tanus*'s Avatar
AZ's Finest!
thats the **** for tool box's right, I thought about that, but couldnt figure a way to hold it on the tank
Old Sep 11, 2007 | 03:26 PM
Sparks!'s Avatar
Yeah thats the stuff, and usually sold in small amounts for car dashs to put stuf on without slipping all over the place.
Someone I know has put it on his tank and grip filled it all on, I gotta ask him what he thinks of it actually if I can get hold of him...
maybe some double sided tape? might have to replace it often but should hold pretty good?
Old Sep 11, 2007 | 08:09 PM
seldon929rr's Avatar
Daddy Squid
seldon929rr is an unknown quantity at this point
Smile Re: Stompgrip worth the money?? + tank dent fix
my buddy uses that stuff. adhesive holds it pretty good and it feels like a little butt pillow.
crf4i50
May 1, 2013 02:06 AM
Napkin Legend
Feb 27, 2013 09:56 AM
f4i knight
Feb 26, 2013 03:06 PM
gotafurrybike
Feb 11, 2013 03:43 PM
bretsmith93si
Oct 9, 2012 10:36 AM
