f4i problem
Old Aug 25, 2007 | 11:50 PM
cr0wn3d's Avatar
cr0wn3d is an unknown quantity at this point
Question f4i problem
im new to sportbikes and i bought an 01 f4i. its supposedly all stock. ive been riding it a bit and now i want to try stunting. ive tried dropping the clutch in 1st at like almost 10,000 RPM going (20 MPH) and it just jolts a bit and then starts picking up speed (with the front tire on the ground). am i doing something wrong? or does it sound like an engine problem
Old Aug 26, 2007 | 12:18 AM
matt360's Avatar
matt360 is an unknown quantity at this point
Re: f4i problem
Um. Maybe your doing something wrong but if it's your clutch. Go down a road shift into 5 or 6th gear and pin it. Hold it open. If your rpms rise and your speed doesn't it's your clutch. What are you doing for clutching it? You have to time everything just right or it won't work like you want it to.
Old Aug 26, 2007 | 10:47 AM
cr0wn3d's Avatar
Re: f4i problem
going about 20 mph i pull the clutch in keeping the throttle open a bit, the rpms slowly start to raise, as they hit about 10000 rpms i drop the clutch (while the throttle is still open) and the bike just lurches forward and then starts to speed up. there doesnt seem like there is enough torque to lift the wheel or something?
Old Aug 26, 2007 | 11:10 AM
Standupnfall's Avatar
Re: f4i problem
Please read the sticky on how to wheelie. Also have your bike looked at by someone who knows what there talking about ( a stunter or mechanic )
Old Aug 26, 2007 | 11:26 AM
cr0wn3d's Avatar
Re: f4i problem
i did read the sticky. i read it before i even tried a wheelie. my bike just seems like there isnt enough power. i think ill have it looked at though thanx
Old Aug 26, 2007 | 05:44 PM
matt360's Avatar
Re: f4i problem
Where in Ny are you from?
Old Aug 27, 2007 | 06:43 AM
Tdeal28's Avatar
Tdeal28 is an unknown quantity at this point
Re: f4i problem
if your bike doesn't have a clutch that is serverly slipping (which you would probably notice while just riding and getting on the throttle) than its your technique.....My F4i is stock gearing and I have no problem getting it up from a stand still.....
Old Aug 27, 2007 | 10:58 AM
cjstunts's Avatar
cjstunts is an unknown quantity at this point
Re: f4i problem
yep. definately doing something wrong.
Old Aug 27, 2007 | 11:56 AM
Wheeliest's Avatar
Scrapes Elbow
Re: f4i problem
just ignore the bucking, if 10k don't work try 11k
Old Aug 28, 2007 | 10:55 AM
cr0wn3d's Avatar
Re: f4i problem
when the clutch is in should the rpms being rising really fast before i dump the clutch?
cuz i wasnt revin it fast at first but instead just slowly got to a certain rpm and then dumped the clutch at the same time as i laid on the throttle more
Old Aug 28, 2007 | 11:00 AM
Wheeliest's Avatar
Scrapes Elbow
Re: f4i problem
goto the stunt video section here on Stuntlife and watch n listen to them clutch it up, that should help you figure out what to do
Old Aug 28, 2007 | 11:04 AM
Re: f4i problem
Westchester, Just north of the BX
Old Aug 28, 2007 | 01:10 PM
matt360's Avatar
Re: f4i problem
In NYC right? Shitty. Why do all stunters in Ny have to be spread out. I was hoping Glens Falls.
Old Aug 28, 2007 | 07:20 PM
joe98's Avatar
joe98 is a decent person
Re: f4i problem
try letting the clutch out slower dont dump it at a certain rpm just give it gas and let out at the same time i had the same problem you want it to all be smooth
Beastin4shot
May 9, 2013 04:49 PM
kchad917
May 2, 2013 07:20 AM
Demon87
Feb 3, 2013 08:58 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
Jeffknight27
Dec 3, 2012 10:55 PM
