newbie questions(please help)
Old Jul 11, 2007 | 05:36 PM
motojoe's Avatar
motojoe is a decent person
For the last two years I have been stunting a supermoto and was not to bad. I recently got an f4i and am now getting into it with that. It is all stock with a pipe and cage. My questions
-Would-1 up front make it alot easier to lift in second?
-If im not doing circles do I need to remove the tip over switch?
-when Im doing 12's how do I keep it smooth going in and out of the balance point. For me its very twitchey/jumpey.
-does anyone else feel a lack of power at 2k to 3k rpm?(flat spot)
If you guys could help me out it would be appreciated
Old Jul 11, 2007 | 06:00 PM
mikkee's Avatar
mikkee is a decent person
Re: newbie questions(please help)
-Going down in the front or up in the back in reguards to gearing is going to give you more torque making you able to get the front wheel up with less gas and clutch.
-You should fix the tipover if your stunting period. You don't just remove it though cuz then the bike won't start there are a few different ways to do it, one of the many f4i stunters on here should be able to help you with that.
-As for being smooth, that just requires seat time and practice just like any trick on any bike for that matter.
- As for lack of power at a certain rpm, maybe plugs, who knows it could be a lot of things. If you just got it you may want to get a tune up.
Old Jul 11, 2007 | 06:27 PM
motojoe's Avatar
Thanks. the bike has 4k miles and was female owned before me so the thing is like new. thanks for the input.
Old Jul 11, 2007 | 09:33 PM
motojoe's Avatar
is the stock 16t, and does anyone know the best place to buy a -1(15t) to use with my stock chain?
Old Jul 13, 2007 | 01:31 PM
tsenfw's Avatar
tsenfw is a decent person
Make:HONDACategory:STREETModel:CBR 600 F4 2001-2005
OEM
Rear 45
Front 16
Chain 525-110
You didn't say what year f4i. You can check stock sprocket sizes here:
http://www.drivenracing.com/content....HONDA&CurModel=
HAI bike shop one of the forum sponsors should have sprockets. If not try www.kneedraggers.com
Old Jul 13, 2007 | 10:55 PM
Stubbz's Avatar
any shop that can get stuff from parts umlimied will be able to get you a 15tooth for 20bucks, you may want to go -1 in front and up a few in the rear, anymore than 3 up in rear you may need a longer chain though
Old Jul 14, 2007 | 01:11 AM
csimp3's Avatar
csimp3 is an unknown quantity at this point
but if you gear your bike higher wont the twitchyness just be worse?
Old Jul 14, 2007 | 09:50 AM
Stubbz's Avatar
thats what ppl say but i thyink it helped mine to be smoother but might have just been me getting better idk
zeus_r6
Aug 23, 2014 04:11 PM
ellbag
Jan 8, 2014 09:30 PM
aj menarde
May 7, 2013 08:27 PM
bretsmith93si
Oct 9, 2012 10:36 AM
BVRider1
Ronin Riders
Dec 1, 2002 02:12 PM
