to those with f4i, oil pickup, and 905
Old Mar 31, 2007 | 11:57 PM
DirtyToes's Avatar
DirtyToes is a decent person
im planning on installing my pickup tomorrow and i'm tryin to plan everything beforehand.
will i need to take off my 905 cage?
also, aside from the headers, would i need to take off anything else?
Old Apr 1, 2007 | 03:31 AM
Scott-'s Avatar
Re: to those with f4i, oil pickup, and 905
if u take off your radiator it makes taking off the hearder even easier just did the stuntex mod on my f4i and holly **** what a difference definitly best money i have spent in a long time plus now u can put some new coolant in
Old Apr 1, 2007 | 02:42 PM
binder929rr's Avatar
back in the saddle again
how is it the best mod you've ever done? if it's doing it's job you shouldn't notice a difference. i put it in my gixxer and i didn't notice **** so i didn't do it on my f4i.
Old Apr 1, 2007 | 02:51 PM
Scott-'s Avatar
well i have a gixxer an 05 and have a pickup in that i really didnt notice anything on that bike, but on the f4i it made a huge difference. the f4i pulls down low so much better and doesnt tend to stall out and runs smoother in 12 oclock wheelies u have to do it to see plus the f4i can live on the limiter with this mod just ask some of the socal stranglers Tony Kendall and Mikey D, its definitly money well spent.
Old Apr 1, 2007 | 02:55 PM
Scott-'s Avatar
if your rollin slow BP idle **** your going to notice a huge differnce.
Old Apr 1, 2007 | 08:28 PM
ic, maybe i'll look into it. mine seems to do good right now so i'm afraid to mess with it too much.
Old Apr 1, 2007 | 09:42 PM
DirtyToes's Avatar
fuuuuuuuuck, i was lookin at the headers today and they looks pretty impossible to take off without taking off the radiator first.
here are the steps i'm gonna take...(correct me if i'm wrong)
drain oil
take off filter
take off radiator
take off headers and exhaust
put bike on 12
take off pan
install pickup
put on headers
put on radiator
install filter
add 3.5qrts of oil (wrong/right)
Old Apr 1, 2007 | 09:50 PM
MR. RYAN SMITH's Avatar
drain oil
take off filter
take off radiator
put bike on 12
take off pan
install pickup
put on headers
put on radiator
install filter
YOU DONT HAVE TO TAKE OFF THE RADIATOR. UNBOLTING THE BOTTOM BRACKET AND LOOSENING THE TOP BOLT WILL ALLOW YOU TO PULL THE RADIATOR FORWARD ENOUGH TO GET THE HEADER OFF. IT ONLY LOOKS CHALLENGING, ONCE YOU GET STARTED EVERYTHING IS PRETTY SELF EXPLANATORY. YOUR LIST LOOKS GOOD THOUGH.
Old Apr 1, 2007 | 09:58 PM
No reason to put the bike on the bar.........
Old Apr 1, 2007 | 11:07 PM
ya, just put the bike on it's side. worked fine for me. that way you don't destroy the bike if it tips over.
also, i use 4 qts in my f4i and it seems to work fine.
Old Apr 2, 2007 | 12:40 AM
DirtyToes's Avatar
okay so after a few hours now...
the radiator is off
the headers are off
my 905 piece that goes under is bent.(long story)
i've got coolant and oil all over me.
all 11 bolts for the oil pan are off
...but the oil pan won't come off!
i've looked through the service manual too, and according to that, the 11 bolts SHOULD open it...
am i missing something?
Old Apr 2, 2007 | 12:57 AM
Might have to shimmy something in there and pry it open
I guess I'm the weird one.. I left my bike on the kickstand to do it
Old Apr 2, 2007 | 02:11 AM
DirtyToes's Avatar
tried that...
snapped off one of my fairing tabs/stays(the one thats a part of the pan..right side of the bike)....hopefully some JB weld will fix that.
still no luck with the pan...****** won't even budge.
Old Apr 2, 2007 | 02:15 AM
I'm sure it's just stuck somehow with the gasket
Old Apr 2, 2007 | 02:20 AM
Tap The Side Of The Pan Lightly And It Will Pop Off, Double Check That There Is Not A Bolt Your Missing.
Old Apr 2, 2007 | 02:59 AM
DirtyToes's Avatar
im sure that ive got all the bolts off.
thought that the drain bolt might be the problem, took that off, still nothing.
and i tapped it with a hammer...tried a screw driver also...still no results
Old Apr 2, 2007 | 04:52 AM
DirtyToes's Avatar
FINALLY!
i was pushing down with a hammer to try any squeez a screw driver into the opening...right when i was about to put in the screw driver, the oil plan just dropped down.... :YEAH
so what ive done so far...
1. pulled out and flipped the "pickup thingy" 180°
2. took off the O-RING
3. put the METAL GASKET on and bend the tab accordingly
so the order from bottom to top is:
1. PICKUP
2. METAL GASKET
3. METAL PLATE
4. O-RING
btw, you were right MR RYAN SMITH, the thing is ****** easy once you get the pan open.
now the problem is that on the METAL PLATE, there is a little cut for the old/stock TAB, but there ISNT a cut for the new "METAL GASKET TAB"....but it is pretty easy to actually make a new cut.
i just want to verify this with someone before actually making the cut. RYAN if you can verify this, itd be great.
here is a pic i just took..and as you can, the pickup does not perfectly fit into the half-moon...but the 2nd cut should let it go right into place?
Old Apr 2, 2007 | 05:04 AM
No Need To Make Any Cuts, It Will All Line Up. YOU HAVE IT RIGHT.
Old Apr 2, 2007 | 05:05 AM
DirtyToes's Avatar
or wait, maybe i got the order wrong?
becaz if i change the order from bottom to top to:
1. PICKUP
2. METAL PLATE
3. METAL GASKET
4. O-RING
...then the tab would fall on top of the plate and there wouldn't be need for a 2nd slit/cut
wrong/right?
