installing oil pickups
Old Mar 14, 2007 | 01:25 PM
DirtyToes's Avatar
DirtyToes is a decent person
so i'm lookin to get a oil pickup soon...
i would assume that you'd hav to open the oil pan? if not, how does it install?
how hard is it?
Old Mar 14, 2007 | 04:04 PM
CHADf's Avatar
Re: installing oil pickups
easy to do on a gixxr6
it's self explanitory when u drop the oil pan on a gxxr.
Old Mar 14, 2007 | 04:06 PM
MR. RYAN SMITH's Avatar
Takes About 1 1/2 Hrs. Take Off The Exhaust, Drop The Pan, Flip Stock Setup 180 With Provided Hardware, Clean And Re-install.
Old Mar 14, 2007 | 04:50 PM
DirtyToes's Avatar
edit:
do i need like a stand or anything? or can i do all this with the bike on kickstand?
Old Mar 23, 2007 | 10:09 PM
DirtyToes's Avatar
ok, i just recieved my pickup today
i had never seen one before....it looks like i got the wrong part?!
what i got looks like a license plate frame.
can someone plz post instructions?
here are some pics: (this is the only piece that i got)
Old Mar 23, 2007 | 10:10 PM
DirtyToes's Avatar
found these on stuntstop.com, are they the "right" instructions?
Remove your oil pan.
Take off your existing pickup.
Install the metal ring tab.
Put your pickup back on but spin it 180 degrees. Make sure you reuse your old seal, or get a new one.
Bend the tab to keep the pickup from turning.
Install the metal gasket ring. This creates a oil build up in the pan where the pickup is.
Put your oil pan back on and start scraping
Old Mar 24, 2007 | 12:23 AM
Your Mail Got Mangled!
Old Mar 24, 2007 | 12:28 AM
NINER's Avatar
Retired
Looks like the pick up for an f4i minus a part, that got bent to ****!
Old Mar 24, 2007 | 03:29 AM
DirtyToes's Avatar
****** sucks....
but at least its the right part
Old Mar 24, 2007 | 01:57 PM
Scott-'s Avatar
put it undernieth a bunch of heavy books it should straighten out fine but your still missing one part
Old May 4, 2007 | 11:40 AM
ERDMANN's Avatar
Stuntriding saves lives!
ERDMANN is an unknown quantity at this point
going to install mine tonight, take off the pick up install smaller metal gasket, and keep the o ring and than put pick up back on spin 180, and bend tab to keep in place, its that simple right??????? all the rest is a no brainer
Beastin4shot
May 9, 2013 04:49 PM
SlitZ
May 6, 2013 06:24 PM
Brian94tt
Apr 12, 2013 07:40 PM
JR 12
Reckless Methods
16
Jul 11, 2003 03:14 PM
NTS
Nov 18, 2002 11:10 PM
