HB on the inside or outside?
Old Sep 25, 2006 | 02:11 AM
1ST GEAR's Avatar
1ST GEAR has a spectacular aura about1ST GEAR has a spectacular aura about1ST GEAR has a spectacular aura about
I have seen it both ways and just curious what the advantages are in each way. I have my HB on the inside right now and run an ASV lever on the outside. My HB isn't hooked up right now to force myself to get better at the rear brake but I went ahead and started mounting everything a few weeks ago when it was raining. I can pull my clutch in with my index but it kills my arms after a few times and I end up 2 fingering it. I am prolly going to switch to a moose and go ahead and hook everything up and start HBing it. Any thoughts from all the HB guys here on which one is better. I am starting to think I would be better with the clutch on the inside since I get worn out after 10 mins. in the lot with one finger.
Old Sep 25, 2006 | 09:08 AM
KF_Chris's Avatar
KF_Chris is a decent person
Re: HB on the inside or outside?
mount the HB inside the clipon mount on some FI clipons and you're golden
Old Sep 25, 2006 | 09:26 AM
I like having the brake inboard. That makes the brake lever 2 inches longer, which means ALOT more brake pressure. There are a handfull of mods you can do to make the clutch pull easier to compensate for a tiny clutch lever.
smallj
Dec 15, 2020 05:12 PM
yuppivore
Apr 22, 2015 01:05 AM
matt-gp8
Oct 10, 2014 12:31 PM
inolen
May 12, 2003 12:29 PM
