problems drifting to the right
Old Aug 27, 2006 | 12:38 PM
rurouni125's Avatar
rurouni125 is an unknown quantity at this point
all summer iv'e been sliding over to the right as soon as i bring up a highway stand-up wheelie. im not sure if its something i'm doing or if it is the bike. ive tried steering it to the left but it makes no difference. i try putting no weight on the right peg and still nothing. the good stunters i ride with say that they have never seen someone go to one side as quickly as i do. does anyone have any idea what the problem could be or any solutions to fixing it. thanks
Old Aug 27, 2006 | 05:00 PM
VerticalLimits's Avatar
VerticalLimits is a decent person
Re: problems drifting to the right
when doing parking lot stuff, i am around 18psi, i've been working on burnouts alot lately, when i go on long trips or go to corner, i bump up to 30. long story short, was on hwy, pulled it up, kept going left real hard, no matter what............ so here's what i did, checked to make sure my tire was straight, which it was, was clueless, my boy asked what direction i was primarily doing burnouts in, which was left, lowered the pressure back down and problem went away. that was my experience............
hope it helps......
Old Aug 27, 2006 | 11:18 PM
crazytexan's Avatar
crazytexan is an unknown quantity at this point
your probably putting alot of weight on the footpeg and not knowing it. also the roads lean off the the right so you could just be going with the road.
Old Aug 27, 2006 | 11:23 PM
that too, guess that would be the most obvious..........duh on my part
Old Aug 28, 2006 | 01:42 AM
rurouni125's Avatar
the roads in my area do slope to the right very badly. but everyone else seems to not have a problem with it except fro me.
Old Aug 28, 2006 | 12:46 PM
Wheeliest's Avatar
Scrapes Elbow
other people ride different, if u have any mechanical skills aim your rear rim the the right and that will put weight onto the left side of the bike when u wheelie. factory wheelie alignment marks can be a few mm's off from being TRUE so it could possibly be an alignment issue or bent swing arm etc..
Old Aug 28, 2006 | 05:29 PM
rydn600f4's Avatar
rydn600f4 is an unknown quantity at this point
+1 i would be willin to bet this is your problem if it shoots over to the right immediatley after you bring it up.
Old Aug 28, 2006 | 05:33 PM
Wheeliest's Avatar
Scrapes Elbow
factory wheel alignment marks on the swing arm at the axle ends can be a few mm's off from being TRUE, so it could possibly be an alignment issue or bent swing arm etc..
there
Old Aug 28, 2006 | 06:12 PM
N.Q.I_Dave's Avatar
The Ego
N.Q.I_Dave is an unknown quantity at this point
I keep doing that. I put it down to the camber of the road, but then sometimes it just keeps going on the straight and narrow.
Are you leaning to the right to try and see round your front fairing? (I dunno how tall you are)
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
pegasus1
Nov 22, 2013 11:30 AM
