different oil pump for wheelies..??
where can i get a oil pump for stunting so i don't run my engine low when i'm up? I herd there were some out there that pumped from a different spot??
- for a '96 GSX-R 750
Re: different oil pump for wheelies..??
I would go to the dealer and see if they can compare the pickuptube from the 96 to the 99 and see if the tube is the same because if it is than maybe a stuntex for a 99 is the same
1wheel-wonder
Aug 28, 2013 07:33 PM
I got it in my 04 gsxr 1000. Check out the sticky for gsr fix.
